We have all seen older 1950's homes with uninsulated walls, line-wire stucco and the single-glazed aluminum or steel sash windows. I recently inspected such a home that also had an old, marginal radiant heating system. They had also replaced all the windows with high-effeciency vinyl double-glazed units and then painted the home inside and out so that it would be more marketable and sell quickly. As a result of the new efficient windows, the original cold plane of the windows that used to cause major condensate buildup has been removed. The new windows no longer attract the condensate and it now builds up on the next-coldest plane... the drywall of the exterior wood-framed walls exposed on the interior. This in turn resulted in major mold buildup. How many of you have seen this type of unintended consequence, and do you warn your clients of the potential for excessive moisture buildup and resulting mold? What would your advice be for the homeowner that is now stuck with this condition?
