111jag
    2
Everything posted by 111jag
  1. It will be a wood burning stove and it looks pretty clear from top to bottom. The only problem is at the bottom it hooks a little bit to the front and the front of the old fireplace is all bricked in except for a cleanout at the bottom. I've vacuumed everything, so it is pretty clean. The question I have is will a 6" fit, or should I use a 5"? Does the 5" meet code standards for wood burning stoves?
  2. Hi, I have a 6" x 9" chimney flue (inside diametre) and was wondering what size of stainless steel flexible chimney liner can be installed? Will a 6" chimney liner fit? Is it a do-it-yourself kinda job? Can I run the line straight to the stove from the top of the chimney or do I need to install a tee with a clean out cap? If you have done this before, can you guide me through it. Thanks in advance,
