id="black"> I am a master electricain with about 28 years in the trade. Right now I am deployed with the Air Force to a base in Kuwait. There have been sopme issues with people getting shocked out here due to defec tive equipment in the shower facilities. These facilities are fed from a split-bus panel (illegal in the U.S., I know...), which has a GFCI main breaker feeding each section of the panel. These GFCI's open all three phases plus the neutral in case of a ground fault. Since these panels are fed from a main distribution panel, the grounds and neutrals are NOT bonded together. An inspection team from the Air Force did a hazard assessment of the suspect facilities and came up with a few recommendations which I do not necessarily agree with. I would like people's thoughts on these suggestions. First, the team sugggested that all grounds and neutrals be bonded together in all panels, even though they are not the service disconnect. Also, I think that bonding the grounds and neutrals together would cause the 60-amp GFCI mains to nuisance trip all the time. Secondly, they want to put GFIC breakers on all branch circuits feeding equipment that may pose a shock hazard such as hot-water heaters, even though such circuits are already protected by the GFCI mains. I suspect that if such a remedy was tried, we would again have probLems with nuisance tripping. Usually putting one GFCI breaker "downstream" of another in the same panel causes these tripping problems. The reason for their suggestions was that they put a meter between the ground and neutral in these panels, and often had a voltage difference between the two points. I tried to explain that anytime you have an unbalance load, (even a small one), there will be a difference in potential between the two points. Anyway, that's what's going on, and again, I'd appreciate any feedback. Thanks in advance; TSGT Scissons
