New Here! Just ran across this looking for code for new oil furnace install chimney liner, and wanted to give a heads up on this topic. The coil can be changed out with another manufacturers but you have to make sure they used the correct piston size on the coil. If not then you would have a change in cooling due to the evaporator starving or flooding. Also before condemning a compressor, make sure a hard start kit was tried! Back to my issue! Installing a new oil furnace, does the chimney have to be lined? TIA Randy
