We have a Consolidated Industries model MBA080NH4R furnace, natural gas, with hot surface ignitor. Control board is a honeywell 406650. Ever since we had our air conditioner (outside and attic split system) replaced, which came with new thermostat (basic digital readout type, though not programmable), our heater has exhibited some issues. Say the house was 63F. we turn on the heat and set it to 69F. The fan in the furnace will kick on, the HSI glows, the flames ignite, nice centered blue flames, I see the flame sensor glowing, and warm air is blowing out of the vents in the rooms like it should be, but just as the wall thermostat reaches around 67F, I notice the air is no longer warm coming from the vents. Upon checking the furnace, I see the fan is still on, but the flames are not. The diagnostic light flashes dim/bright as is noted to be normal operation per diagnostic code table. The furnace brought the house up to 69F at one point later on in the night, satisfying the tstat setting, but when the house dropped back down to 67F, and the furnace began its startup sequence, it sometimes lights and blows warm air for a few minutes, then the flames go off, and the fan stays on(set to auto). I at one point saw the HSI start to glow, then go out. So I just shut it off for a couple of hours. If we turn it back on, it rarely but usually does not ignite with flames, but just blows ambient air. At times I have been able to turn the power off in the attic switch and turn it back on to "reset" it, but that doesnt seem to do anything anymore. Even though the diagnostic light glows bright/dim at all times, throughout all this, it still acts like what the manual says occurs with a burner limit circuit open. I just dont get how it can work nicely for thirty minutes at one time, satisfy the tstat, but then not be able to come back on .
