frustrated_tech
    2
Everything posted by frustrated_tech
  1. It's the original motor that came with the unit...I always use the same RPM motors that i take off...as far as pitch, these units, the coils are straight up and down...yes the drain is unclogged, i poured several glassed of water after i blew out the line...thanks for all the replies, give me more if you can think of anything...oh and these units are First Company, condensors are rheem, ruud, goodman, all different....
  2. I have had many calls for water leaking from the ducts of a fir down evaporator, 1 1/2 ton r-22 units, apartments. I clean the coils, clean the squirrel cages, make sure the drip pan is draining and it still blows or leaks into the duct....without removing the entire evaporator is there a way to repair this problem or something else to check...I'm thinking by the time its gets this bad the coils probably need replacing? what do you guys think
