Thanks so much everyone... Your advice has been very helpful. I will have someone look at the crawl space under the house since this seems like the most likely cause. There is no insulation under there that I am aware of but I am not/do not/will not crawl under there! [:-bigeyes. Next, as an additional precaution, do you think it will help if I float the floor? Seems that it adds an additional moisture barrier to do that. Also, I am leaning toward a Hampton Hickory 5 in plank or a Bruce Townsville 5 in plank. On the Hickory the thickness is 9/16th and it doesn't say on the sample anything about the installation. The Bruce have to find in 5 in. though. Also says glue or staple down. and is only 3/8th in thick. Other than for possible resanding at some point, is there any reason to get more thickness? Is Oak better or Hickory? I have Oak now. Thanks again.
