As a certified hardwood inspector with the NWFA I can tell you you need to do the following. 1. The grading must slope away from the house. If this is not feasible install a french drain. Imperative! 2. Get someone with the proper tools and knowledge to assess the crawl space, the subfloor and the hardwood for moisture content, humidity and temperature try http://www.woodflooringinspectors.com/ for an inspector near you. 3. Does the crawlspace have adequate vents to the outside and do they adhere to local building codes? 4. Definitely the ground should be covered by 6 mil black poly taped up the wall. 5. Every box of hardwood has the manufacturer's installation guidelines along with warranty and maintenance guidelines. Not adhering to these will void any warranty with the mfg. 6.Temperature and humidity levels must be between 60 degrees to 80 degrees f and 30% to 50% humidity levels excessive humidity will cause cupping.Even if unoccupied!!! 7. Acclimation not properly adhered to can cause permanent cupping which can only be fixed by a sand and finish IF the subfloor moisture content is less than 12%. And the subfloor and solid hardwood cannot have a difference of more than 4% for 2 1/4" or more than 2% for 3" or wider. If this occurs the cause must be determined before continuing. I cannot stress enough to follow manufacturer's guidelines. It distresses me to see what consumers are subjected to regarding nailing schedule, proper subfloor, proper spacing at the walls, inferior adhesive and general lack of installation knowledge by installers. If yours does not have a moisture meter find one that does or you will never know when it is proper to proceed.The installer will need one capable of testing concrete as well as the hardwood. Most only do one or the other. 8. Subfloor over concrete is always plywood cdx exposure 1. 1/2" by NWFA guidelines though most mfg require 3/4" and always adhere to mfg guidelines.
