Mark Anderson
Mark Anderson's Achievements
  1. There are EXTERIOR cracks/cracked parging so they need to be repaired/waterproofed on the outside. Underground roots can cause these cracks as well as lateral soil pressure so,exterior waterproofing done/backfilled correctly would reduce-lessen the soil pressure as well as removing any roots against the wall. http://picasaweb.google.com/10104903458 ... roofing09# Underground root (pic's 3-9) caused the step cracks etc seen inside(pic's 15-17) and exterior cracks etc outside which then allowed water to enter basement at floor-wall joint,cove,cold joint.(pic 19) And sometimes the blocks and-or joints will deteriorate.....see deterioration of some blocks,joints....side wall is bowed in. Just putting some wall anchors or beams etc inside will not reduce any lateral pressure and won't remove any underground roots etc,won't stop FURTHER DETERIORATION and won't stop further water from(any inside system will not) http://picasaweb.google.com/10104903458 ... 3328086770 Here, an interior knothead system was installed all the way around,some beams installed on/against 1 wall....over $17,000 spent and they STILL have the same problems,worsening problems. http://picasaweb.google.com/10104903458 ... roofing41# Some cracks are widening,still leaks,2 wall bowed in...more mold,more efflorescence.Job,the problems were misrepresented are usual by dingbat inside system companies....for self gain=fraud.
