Most drain cleaning products are designed to clear blockages, so if the drain has been emptying slowly their use is generally not as effective. The chemicals will drain away just as the water and will usually eat away a small channel in the grime at the bottom of the pipe; but it will not clear the whole pipe. This will mean that the drainage may only improve for a short period of time.
