I will be starting work on a bathroom on the second story of an old Victorian home (130 years old). The room has no plumbing at all. I have access through the walls to run all the lines (waste/service, etc) from the basement. My service lines will run about 15 feet horizontal) in the basement and then climb approximiately 32 feet vertical to the bathroom. Once in the room I will distribute to two sinks, 1 tub, 1 shower and a toilet. I have done a good deal of work over the years with copper but never PEX. I am thinking since I have no plumbing in this room, PEX might be a better alternative. My thought is to install two manifolds in the basement (hot/cold) and then distribvute from there (i.e. vertical) I have a few questions.... 1. Is PEX better than copper at all? 2. If I go PEX, what vendor is recommended for products? 3. I have looked online and see that the manifolds are either stainless, potable, radiant, etc. I assume potable is the way to go? 4. I have 3/4 " service lines in the basement to pull from. I was thinking of running 3/4" copper to the manifolds and then PEX from there. Should I stay 3/4" PEX or 1/2" or go bigger (i.e. 1 inch)? I apologize is this is redundant for all but I appreciate the feedback.
