There is no where it says its OK to do it, there was no where that said you can't do it prior to 2008. 250.32 Buildings or Structures Supplied by a Feeder(s) or Branch Circuit(s) (B) Grounded Systems. (1) Supplied by a Feeder or Branch Circuit. An equipment grounding conductor, as described in 250.118, shall be run with the supply conductors and be connected to the building or structure disconnecting means and to the grounding electrode(s). The equipment grounding conductor shall be used for grounding or bonding of equipment, structures, or frames required to be grounded or bonded. The equipment grounding conductor shall be sized in accordance with 250.122. Any installed grounded conductor shall not be connected to the equipment grounding conductor or to the grounding electrode(s). Exception: For installations made in compliance with previous editions of this Code that permitted such connection, the grounded conductor run with the supply to the building or structure shall be permitted to serve as the ground-fault return path if all of the following requirements continue to be met: (1) An equipment grounding conductor is not run with the supply to the building or structure. (2) There are no continuous metallic paths bonded to the grounding system in each building or structure involved. (3) Ground-fault protection of equipment has not been installed on the supply side of the feeder(s). Section 250.32(B) requires the installation of an equipment grounding conductor with all feeders and branch circuits that supply a building or structure. Using the grounded conductor to ground equipment, in lieu of installing a separate equipment grounding conductor, creates parallel paths for normal neutral current along metal raceways, metal piping, metal cable sheaths or shields, and other metal structures such as ductwork. Installing an equipment grounding conductor with the supply circuit conductors helps ensure that normal circuit current is not imposed on continuous metal paths other than the insulated grounded or neutral conductor. At a building or structure supplied by a feeder or branch circuit, the equipment grounding conductor is connected to the grounding electrode system [unless the installation complies with 250.32(A), Exception] in the equipment supplied by the feeder or branch circuit. Where installed, the grounded or neutral conductor is electrically isolated from the equipment grounding conductor and any grounding electrodes at the building or structure supplied by the feeder or branch circuit as illustrated in Exhibit 250.19.
