Hey all. I'm having a problem with a leak coming from the condenser drainage pan of my Apollo AC system. The leak occurs when the AC has been running long enough for the pan to fill up completely. At this point it seems to spill over at a very slow trickle from the top of what I am assuming is the primary drain pipe. There is a second pipe set to the left and slightly above the main pipe, and I am assuming this is an emergency/overflow drain. If I turn the AC off when the pan is full/leaking, then the water will recede to the level of the bottom lip of the left (overflow?) pipe and stop. At this point there is no more leak, but the remaining water in the pan will not drain. My questions: Do I have the mechanics of this system correct? Is the right-side pipe blocked in some way that is preventing drainage? If so, is there anything I can do to fix the problem? Thanks for any help you guys can offer. I will include some pictures of the pipes below. Click to Enlarge 56.46 KB Click to Enlarge 56.99 KB
