Thanks for your reply, Marc. The coolant coil has never been used, (either for R22 OR 410A), because the previous (and original) owner never installed air conditioning. The Apollo Hydro Heat system in question, however, dates to 1990, so it is unlikely that it will be labeled as compatible with 410A, which didn't come along until later(?). A neighbor with the same Apollo system installed a Puron-based high efficiency Carrier AC unit about 10 years ago and it's working fine. If the coolant coil is clean (virgin) what are the other obstacles to installing a high-efficiency (R410A) unit? Thanks again!!!
