Actually stumbled across this old thread while doing a google search looking for a specific epa link. Kinda amazed at the lack of knowledge on the subject matter in the home inspection field. Vermiculite is a product that is very unique when compared to any of the other 10,000 products that contain asbestos. The reason for this is quite simple. Asbestos was not intentionally put into vermiculite, but rather is a contaminate of the product. How is this possible? 95% of all vermiculite was mined in Libby Montanna prior to roughly 1985 (the mine itself was operational another 5 years but production tapered off). It just so happens, that tremolite asbestos was also present in the same mine. The veins of each mineral intertwined and separated then met again, in such a way that the actual amount of asbestos present could vary quite substantially. This presents a significant problem in testing. Unlike a manufactured material, such as floor tile, the distribution of the asbestos will vary greatly. You can literally pull 100 samples from different locations in an attic, and get quite a wide range of results. Also to consider is the manner in which the sample is pulled, you will almost always get a higher reading if you dig down deep into the vermiculite (where the fines are located). Understanding how normal Asbestos bulk samples are analyzed also adds to the confusion. Typically speaking a lab tech would pull a small piece of a suspect material, tease it and then place it under a polarizing light microscope. He then begins to determine if asbestos is present, and if so, at what concentration. You need to understand, this sample he is looking at is so minutely small (think of something the size of the head of a pin, only smaller), and you can start to see why it is nearly impossible to conclusively say that no asbestos is present when dealing with the uniqueness of vermiculite (once again due to the fact that asbestos was a contaminate and not added intentionally).
