Inspector1
    24
Recent Profile Visitors
Inspector1's Achievements
New Member
New Member (2/5)
  1. The garbage disposal gets so hot that they have a NAPA radiator hose hooked up with 90 mile an hour duct tape. Click to Enlarge 42.02 KB [:-monkeyd [:-wiltel]
  2. I was inspecting a 1960's duplex, The property manager stated that they had some water that had run down the service mast but they had repaired it with no additional problems. Click to Enlarge 81.86 KB Click to Enlarge 73.64 KB I think it looks like they came from the Titanic.
  3. Check out where someone cut off the elbow for the intake valve for the furnace in the crawlspace. Previously it was vented five to the exterior. Allowable ever.??? Click to Enlarge 37.42 KB
  4. Any ideas as to why this is happening? This has only happened (a few times) when I'm checking the outlets in shops. When inserting the big tester into an outlet I get a bad ground reading. If I double check it with a smaller tester it shows the same outlet to be wired properly. Click to Enlarge 24.36 KB Click to Enlarge 24.94 KB [:-magnify [:-monkeyd
  5. Thanks
  6. What advise do you give to your client on reducing the moisture in the attic?
  7. I found microbial growths in a vented attic. The house was 21 years old, original roof. The venting appeared to be properly installed. The ridge vents had wide gaps at the top. The enclosed soffits were not blocked with insulation, but there was microbial growths on the sheathing. Normally its caused from lack of or blocked vents. Any suggestions. Click to Enlarge 52.57 KB Click to Enlarge 60.33 KB Click to Enlarge 57.73 KB Click to Enlarge 61.53 KB Click to Enlarge 38.4 KB
  8. Really old panel 9/21/1956. They rewired the outdoor box but some left the wires in the panel hot. Click to Enlarge 36.78 KB Click to Enlarge 53.78 KB Click to Enlarge 58.75 KB Click to Enlarge 52.34 KB [:-censore
  9. I came across this old Collins water heater that was working but had a small leak. Incredible Click to Enlarge 35.34 KB Click to Enlarge 30.98 KB Click to Enlarge 53.11 KB [:-monkeyd
  10. Looks like they know that they have a PROBLEM. Click to Enlarge 27.74 KB Click to Enlarge 30.34 KB [:-monkeyd
  11. I came across this black short pipe in the crawl space. It was located near the access door away from any plumbing pipe. Possible future Radon system?? Click to Enlarge 45.38 KB Click to Enlarge 46.66 KB Click to Enlarge 42.86 KB [:-bigeyes [:-alien]
  12. With some routine monitoring and shimming I think the deck will make it. Click to Enlarge 66.91 KB Click to Enlarge 63.38 KB Click to Enlarge 56.11 KB [:-thumbu]
  13. Is there a guidelines for log floor joist in the basement. Its been there 100 years so far. Click to Enlarge 51 KB Click to Enlarge 59.18 KB [:-thumbu] Click to Enlarge 55.06 KB
  14. Maybe not recalled but other evidence of "safety issues", The electricians that I have spoke to almost always change them out.
  15. I was inspecting a condo unit. I came across a Federal Pacific Electric with "Stab-Lok" circuit breakers. The panel was clean as a whistle. The condo was 34 years old. Are all Federal Pacific Electric recalled. I'm sure this unit has been inspected before. Would the condo association ever have all the panels changed out? I recommended that it be evaluated by a electrician. Click to Enlarge 41.25 KB Click to Enlarge 58.99 KB Click to Enlarge 61.42 KB
