BigAl
BigAl's Achievements
  1. I have the problem of a home with a slab and pipes in the slab being too small to handle modern washing machines that power massive amounts of water volume through the stand pipe. With not enough gravity space for volume discharge, the stand pipe overflows. We bought a front loading energy star washer that used a lot less water but my wife didn't like the way it cleaned even though it was the best you could buy. I had put a larger stand pipe in to help fix the problem before buying the LG but it wouldn't hold the standard washing discharge. I can't put a larger pipe in wall because of space. Wife does not want a sink in the laundry room, so I decided that tomorrow, I'm going to get a sewer pvc pipe, and elbow(s) to tie into the line going to the pea trap. Use enough adapters or rubber to attach the large pvc pipe to the drain as the new stand pipe. It will hold the max amount of water the tub will have at any given time so discharge would never overflow the stand pipe. It would act exactly like a sink with out the sink. What do you folks think?
