* Make sure that the bath fan exhaust goes out through a vent that's high on the roof. If it goes out through a soffit vent, then there's a good chance that the moist, humid air is just being drawn back into the attic.>>>> Its vented through a wall at the end of the house w no soffit. * If the insulation in your attic is damp, you have a condensation problem. Nothing else that you do will help in any way until you solve the condensation problem. >>>>> what is the best way to find where the indoor air is getting up there. I thaught I found it years ago when I found and closed a gaping hole around the chimney. I havn't found any others.
