Check It Out
    2
    Inspector
Check It Out's Achievements
  1. This condition in incorrect. If you have two circuits tapped into one breaker 15 or 20 amp by a wire nut or any other means and there are twenty outlets on total from both lines than this one circuit is overloaded and not safe. It should be corrected. If a circuit line is shortened in the panel and a wire nut is used to extend it to the breaker that is allowed. As to nuisance tripping, that potentially is a safety concern since you really can"t identify the cause with out further diagnosing the problem.
  2. Some juridictions allow it if no more than three neutrals are crimped together and then placed in the lug.
