SamNorwich
    4
Everything posted by SamNorwich
  1. Unless you are going to put about a five inch think layer of paint on the house, I doubt it is worth the extra money. Heck the color you select may have more of an effect on the heating and cooling of your house than any additive. I'd proceed with caution and do much more research. Sam N Indianapolis Real Estate
  2. It is funny how the media jumped all over a couple of stories about mold and turned a common problem into the swine flu epidemic of old homes. Sure there are some dangerous and difficult mold problems to contend with, but the majority of the mold problems can be fixed with some cleaning and repair. It is good to get a couple of opinions first though, just as you did. Sam N Indianapolis Real Estate
  3. You think builders used to cut corners, well the last two years of a sucky economy hasn't helped one bit. I have seen everything from 'homemade' vents to no vents at all. This job is getting harder every day and the more I report the more friends I 'make' [] Sam N Indianapolis Real Estate
  4. I have seen where over insulation has blocked attic ventilation. This is dangerous, not only for heat, but for moisture buildup and even release of gases. It is best to have a well ventilated attic and your inspection report should site making improvements in that area. Sam N Indianapolis Real Estate Inspector
