Gotta disagree. Appearances are important to sellers; it's a pride of ownership thing. It doesn't matter whether or not the stuff behind the paint is rotten, we shouldn't be destroying the finished surface of a house -- even if that finished surface is less than a millimeter thick. If the damage is that bad, we ought to be able to detect it without causing cosmetic damage. There's really very little wiggle room there. It's written in plain English. "Probing is NOT required when probing would damage any finished surface." (The all caps NOT is part of the ASHI standard. I didn't add it.) What's there to "read into it?" Two posts ago, you misrepresented the ASHI SOP in an attempt to convince people that ASHI required probing of finished surfaces, when, in fact, the opposite is true. If you want to probe finished surfaces, fine. But don't tell folks that ASHI requires it. Actually, it's called a brashness test. And it doesn't work as you've described. A brashness test, by definition, damages the wood that you're testing whether it's rotted or not. To do a brashness test, you insert a screwdriver (or an ice pick or an awl) into the wood and you lever it to lift a string of the wood grain off the surface of the wood. If the lifted section of wood breaks in a line perpendicular to the grain, just above the probe, then you've discovered rot. If it breaks to one side or the other or if it just splinters apart, then you haven't necessarily disproved the presence of rot. The rot may still be present but hasn't advanced to a detectible stage yet. A brashness test will severely mar sound wood. I'm not offended, just disheartened that people think they have to act like cowboys when inspecting a house. - Jim Katen, Oregon Jim, I reject the comment that I am a "cowboy" inspector or what you are insinuating as a maverick that goes against the grain of inspecting. You have no idea of my professionalism in the field, my success as an inspector or my credentials to make such a blanket comment. I am not trying to convince anyone of anything. Just rendering my opinions and as you have done. Spirited discussion is one thing. This is moving beyond that into debate and bantering. You have your opinion. I have mind. Lets just say we agree to disagree. I will not be your goat to be drug into further bantering in trying to prove a point or debate the issue. You win! Thread killed! SR
