ronpalinkas
    Afghanistan
ronpalinkas's Achievements
  1. Greetings; I am a distributor for the Geyser heat pump water heater in south florida. I would be happy to answer any questions I can about how well it works in a residential application. I have always felt that there was a specific market for the Geyser in south florida. Some of the characterisitics of homes make the Geyser a pretty good solution. Basically, most water heaters are electric, in the garage, and next to the air handler unit (you can use the installed air handler drain to drain the condensate from the Geyser without having to run a separate drain line.) Some of the other advantages have to do with the climate. It is unusual for the temperature to drop below 32F, and for at least 6 months of the year I would estimate that most garage temperatures are greater than 85F. If anyone has any questions specific to the Geyser , I will certainly do my best to answer them. Regards, Ron Palinkas
