stevetheplumber919
Everything posted by stevetheplumber919
  1. The bigger question here is why in God's name you'd want to have 90psi running through a house??? Higher pressure = bigger problems. Unless you need to turn your shower into a blasting tank, a pressure regulator should be installed.
  2. The #1 spot to check is the HWT connections. If you're OK there, you're probably OK elsewhere as well.
  3. Is radon testing something to be considered? I'm looking at a program from 96radon.com that is offering testing in Ontario. Any thoughts
