zarajohn
Everything posted by zarajohn
  1. Hello, Lennox offers a solar powered controlled heat pump. The solar modules give the power need to work the heat pump. The owner can buy the Sun Source? Solar Ready alternative and add as many Lennox solar modules as wanted. Thanks Zarajohn@
  2. Really? Why? What concentration? Really? Yes. Why? No toxic fumes. Concentration? Three percent is fine. Put it in a spray bottle, spray, let set for 10 minutes, scrub, then wipe clean. HELLO, One reason is that bleach cannot totally murder mold developing in permeable materials. The chlorine in bleach cannot enter into porous surfaces for example, drywall or wood. The chlorine is left on the surface of porous materials and only the water component of the bleach is absorbed into the material, giving more moisture for the mold to feed on. A portion of the mold at first surface may be killed however the roots of the mold are left in place importance the mold before long returns, abandoning you in a cycle of rehashed dying. Maybe this is the reason a few individuals accept that spraying bleach on mold doesn't affect it however rather just bleaches its shading so you can no more see it. Another weakness of bleach is that it can harm the materials it's utilized on as it is an unforgiving, corrosive chemical. Chlorine bleach also gives off harsh fumes and it even produces toxic gas when mixed with ammonia. There are more secure options, for example, borax or vinegar which don't create risk fumes or leave behind toxic residue. Thanks
  3. hi I can't consider any individual who might have an open window when it?s that cool, but he claims that the plumber will testify for that. Could you let me know what happens when a radiator bursts because the pipes froze, as opposed to what happens when there is a defect in the rad itself? As I said, minor gaps started to form, consistently, along a single one of the rad's vertical tubes. What could precipitate that? At long last, all the rads have two pipes going down. They have an outlet for bleeding and a round key/wheel to turn them on and off. What type of system would that be? It's more than 80 years age and has never been changed save for the furnace. I realize that the furnace has a temperature and a pressure setting. Thanks
