Rocon
    274
Everything posted by Rocon
  1. let me clarify Paint is a liquid solution of pigment in a suitable vehicle of oil,organic solvent, or water: liquid when applied but dries to form an adherant, protective, and decorative coating. T-1-11 is not a product number it is a specification/ product type. It is an exterior grade plywood with channel grooves. Really the paint would only be a component of an assembly. My main concern is t1-11 a weatherproof panel as is or does it need another component 'IE paint' to perform as a weatherproof panel and does it require a WRB?
  2. I am trying to nail down some questions for a litigation case. The project in question was built in 1973 . The project is located in California, 1997 CBC is identical to the 1973 UBC and states thatWRB can be ommited if the exterior covering is of approved weatherproof panels. Is T-1-11 siding a weatherproof panel? Was WRB required between t-1-11 siding and framing in 1973? Does the paint constitute a barrier coating? Is paint a weatherproof coating?
  3. A soffit is the exposed undersurface of any overhead component of a building. A canteleiver is a Beam,girder,structural member or surface that projects horizontaly beyond it's vertical support, such as a wall or a column. I would phrase it as : The exterior wood finish attached to the first floor canteliever located at the northwest corner of the home.
