dnoel
Content Count
10 -
Community Reputation
0 NeutralAbout dnoel
Rank
Location
Canada
Occupation
The actual ground is probably not connected but something is shorting the receptacles 'ground'. Is this plug connected to a switch ?
I was gonna say.... Each heating/domestic system has different needs. Though, I haven't seen a consumer use tankless system needing an expansion tank. Personally, I don't like the tankless method. Seems to waste energy when you have larger families. Great for the cottage though, where the demand is low. [:-party]
That's panned joist - a duct made by applying sheet metal across the bottoms of two adjacent joists. The staples are going into the wood on the side and through the metal and into the wood on the bottom. - Jim Katen, Oregon Somehow though, that entire panel seemed electrified. If you brought the voltage sensor anywhere along it.... BEEEP!!!! [:-bigeyes If you're talking about those non-contact volt sticks, it might not have been telling you that the entire panel was electrified. Those testers aren't really voltage detectors, they're electric field detectors. The ungrounded c
No mentioned it .... these guys live underground and ruin your lawn. You'll see yellow patches where they concentrate. Grubs they be, damned they be.
Throw a circulating pump and a couple of solar panels and you got yourself a reservoir. I don't see any AO Promax storage tanks that look like this one though. [:-cyclops
Ok, just to clarify. The George Foreman Grill? Aren't the heating plates electrically isolated? (I don't have one - I know someone whose GFG almost burned down their house) Do you have a sump pump? Call an electrician. Mind you - I'm probably trolling here at 2 weeks old.
Apprentice installer? "This is how you do it..." -Does it right a couple times "Ok got it!"
Aha! Good catch - yes, indeed, it is #8 stove wire. I pulled down the ceiling and found these gems. There is two stove wires tight up against a heating pipe and stapled to the heating duct and supported by bent nails. Because of the duct and other wire, there was a magnetic field being created making three different makes of voltage detectors go nuts anywhere within 5 feet of this alcove. Anyone ever see that before? ---- Apparently, our previous owners were very industrious and very drunk and hid all the problems in the house before the sale (which was still a decent pr
Hello All, New to the forum - pleased to be here. I would like to share this photo from my house. This is three #10 wire being spliced to three + ground #10 wire. What makes this situation amusing is that it was completely encased in the ceiling behind drywall and literally 3 feet away from a metal junction box (sans cover) which was also encased in the ceiling. So this run is spliced twice and both splices wrong. [:-sour] Click to Enlarge 46 KB Click to Enlarge 32.49 KB[:-wiltel] Obviously, there's more things wrong.... can you see them?
