The tiny leaks that can't be found with bubbles might not even be leaks. You are aware of all of the things that your sniffer will react to, right? If there're aren't bubbles, I have a hard time believing that the gas leak (if it actually is one) is worth fixing. It certainly doesn't pose a hazard and the amount of money that's wasted is really, really, tiny. - Jim Katen, Oregon
Yes, I am aware and have indeed gotten "false readings" here and there but I do not solely rely on the sniffer to detect a leak. I do verify leak with bubbles. Perfect example: I went out to a customer's house for an "issue" with gas water heater. Arrived at the call to find the knob on the gas valve melted. During my questioning of the customer, realized that the husband (we'll call him Mr. Fix-it) had went to the local hardware store and bought a new thermocouple b/c of a constant pilot outage. this was one full month before this "issue". I was able to get the pilot relit only to find that the pilot tube connection to gas valve was barely tighter than hand tight. This was a small leak but a leak none the less. His response, "I thought I smelled a little gas but I thought it was just when it first fired up. Luckily they were home when this occured or they would have came back to a stack of charred wood. Just sayin'.
