I am wiring my detached garage and was wondering if any of you could look at pictures and offer advice? It is a 30x30. I put in a 100 amp sub panel. I have 11 outlets on one circuit.
No pictures.
I used to live in Bowling Green, KY about 9 years ago. I use to live on Ridgecrest off of Smallhouse Road close to 231.
Do they still have the signs up on every intersection of Scottsville Road showing the running count of accidents on each of those intersections for the current year?
There is no limit to the number of outlets on a circuit. However, you need to calculate the amount of amps you plan on drawing on that circuit. Since it is in a garage there may be work going on. If you have workshop in the garage a circuit could get some heavy use with more than one power tool running at the same time. Also you may want to adda 20 circuit if you have a workshop. In addition, make sure all outlets in your garage are GFCI protected. By the way it is not a sub panel but is a distribution panel.
