I'm going to check out a house of a girl I just started seeing. She bought it 2 years ago and it was built in the 70's. Conversation came up when I mentioned I was starting a HI business. She had some questions about he inspection that was done for her. Apparently, the HI reported that a couple "support" beams in the basement were incorrectly installed and needed to be replaced as well as two other walls "braced" with beams. He also mentioned this should be a contingency of the purchase. Mind you he found no other evidence of cracking or movement. Just that the beams were incorect and the owner needed to get a contractor to fix and add. That was done. Now she is finding "creases" in the first floor walls and cracking(sounded like lateral displacement) in the foundation walls. She called the HI, he came to take a look, told her everything was fine, set up a plumb bob in the basement with a mark on the floor. "You're ok until the bob get to this point. By the way, I won't charge you for this re-inspect." Besides all the disregarding of any Standards of Practice, anyone come across this? Additional beams/support structures activating a crack or foundation? I'll get some pictures when/if I get over there. I'm not sure if I want to tell her what I really think. I suspect she certainly won't want to hear it.
