patt
    90
Everything posted by patt
  1. Chad Insulation The "bottom material"/"belly paper" actually help hold the insulation in place, what you're seeing is standard. Many manufacturers place the duct work below the the floor joist and this creat a further sag in the bottom paper. The major problem you can run into is when there are tears in the material and the manufacturer uses loose insulation.
  2. Chad Manufactured not modular, Shingles Common problem, there was a air foil attached at the gable end See the Asphalt Roofing Manufacturers Association’s Guidelines for Manufactured Housing. ARMA Guidelines, Sec. 4.0, Special Transit Considerations Para.2. “Special Precautions should be used to protect the roof in transit, such as full roof covering with plastic sheet, or net,airfoils, nailer strips to hold shingles down. Any residual damage from these techniques, such as fastener penetration through exposed shingles, must repaired or replaced.…â€
