patt
90 -
Everything posted by patt
That's lap. I have all the Masonite from the late nineties but they won't help you.
Year? Panel or lap?
They'd help a great deal. Could you post them here or in the library, or email them to jim@benchmarkinspections.com ? Thanks, - Jim Katen, Oregon Sent
I have the 11/03 instructions if that would help.
Hardi kick out flashing- when did they start.
patt replied to Brandon Whitmore's topic in Exteriors Forum
Brandon I have either in hard copy or electronic most of the Hardi installation instruction for the last ten years or so. If and when you do any litigation work it pays to have a good library. The attached file for roofing "best practices" is the only file I have prior to 2005 that calls for a kick out, even the 2006 NRCA Roofing and Waterproofing Manualââ¬âFifth Edition describes the kick out flashing as optional. Download Attachment: Roof to Wall Flashing.pdf 120.72 KB -
Brandon The earliest Hardi instructions I have that show the kick out detail, both plank and panel, are the 05 instructions with a print date of 09/05 and effective date of 12/05. The 04 instructions don't depict any kick out flashings. Download Attachment: Hardi 12-05.pdf 175.52 KB -
Jim, Do you write it up, or have you ever considered writing it up? Brandon Sorry to barge in to your question to Jim but I do litigation work so I'll always write it up.
Bill and Mike FYI California has been on the Uniform Plumbing Code for decades and printed with the code are the installation standards. Some of these years ago had to be adopted separately by the AHJ but under the current code the protection required all approved plastic piping is adopted statewide. 2007 California Plumbing Code Installation Standard ABS BUILDING DRAIN, WASTE, AND VENT PIPE AND FITTINGS IAPMO IS 5-2003 2.2.3 Exposed Piping Piping shall not be exposed to direct sunlight. Exception: Vent piping through roof. Plumbing vents through roof, exposed to sunlight, shall be protected by water base synthetic latex paints. Adequate support shall be provided where ABS piping is exposed to wind, snow, and ice loading. Installation Standard PVC BUILDING DRAIN, WASTE AND VENT PIPE AND FITTINGS IAPMO IS 9-2003 2.3.3 Exposed Piping Piping shall not be exposed to direct sunlight. Exception: Vent piping through roof. Plumbing vents through roof, exposed to sunlight, shall be protected by water base synthetic latex paints. Adequate support shall be provided where PVC piping is exposed to wind, snow and ice loading.
Some of 05 and 07 Anderson Information. I don't know if the had anything specific for 06. You'll have to rotate the 07. Download Attachment: Anderson 200 400 07.pdf 932.5 KB Download Attachment: Anderson 05.pdf 576.33 KB
Ca. Mobile Seismic Bracing Requirements
patt replied to inspectorwill's topic in Foundation Systems Forum
The "foundation system" is approved by "HCD" (CA Dept. of Housing and Community Development" not HUD. See your other post about using the correct terminology, you really don't want to mix "foundation systems" and "Earthquake Resistant Bracing Systems (ERBS)". Do a Google search for "Maxi-Pier foundation system" and take a look at the stamp on the bottom pf the page. -
Manufactured Home Foundation Question
Just a note on terminology unless you know for sure that it is a "foundation system" you should just call it the "system support". A 1973 home, at the time of installation, would not have required any attachment to its support system. In CA you install the home to manufacturers' installation, plus since 1994 there has been a requirement for a "tie-down system". Tie-down systems are to prevent over turning and lateral movement caused by wind loads. The tie-down system used can be the typical auger and straps, the instructions for which are included with the manufacturers instructions for the set up of the home, or an engineered pier system which is what is most commonly seen. Additionally in CA you also have "Foundation systems" and "Earthquake Resistant Bracing Systems (ERBS)". Foundation systems are really just a combination of the manufacturers basic support requirements, and tie-down and seismic requirements. Foundation systems may consist of just an additional pier system or may utilize a perimeter concrete or cmu stem wall. If the home is placed on private land, not rented land, and a "foundation system" is used then the home can be considered as an "a fixture or improvement to the real property" in effect converting it from personal property to real property and qualifying for better financing. Attached is a drawing of one manufacturer's home attachment to a stem wall foundation, from either outside or underneath you would not be able to see the connection. Download Attachment: Stem wall.pdf 138.64 KB -
Looks sloppy, drain flange should be supported all the way around. Download Attachment: Drain shower.pdf 830.03 KB
These are from 97 but similar to previous. I check my files to see if I have any earlier. Download Attachment: 202 panel pdf.pdf 1095.56 KB Download Attachment: 201 lap.pdf 1128.47 KB
sure Click to Enlarge 420 KB Click to Enlarge 422.73 KB Click to Enlarge 811.3 KB Click to Enlarge 76.68 KB
Hardiplank 2001 Download Attachment: Hardie plank 2001.pdf 249.58 KB NER report 2000 Download Attachment: ner 405 Hardi 2000.pdf 350.42 KB
See sections 3.2.1.2, I have no idea what a Off-Stud Splice Device is. Download Attachment: ner 405 Hardi 12-1-00.pdf 202.28 KB
Both old and new ES reports Download Attachment: Trex ES report 2003.pdf 120.61 KB Download Attachment: ESR-1190 Trex.pdf 200.86 KB
some info on wind and water Download Attachment: Why 1-inch overlap works.pdf 49.12 KB
Perfectly proper to mount the meter bases on a manufactured home, pedestals are mainly seen in MH parks. Click to Enlarge 26.09 KB Click to Enlarge 24.66 KB Click to Enlarge 28.98 KB Click to Enlarge 24.49 KB Click to Enlarge 26.83 KB In California MHs can be installed on most real property parcels (including city lots) zoned for single family housing. Local zoning and architectural requirements will apply. Click to Enlarge 41.69 KB The Feds passed a law a ways back prohibiting discrimination against manufactured housing and the states have adopted rules and regulation dealing with the installations of MH on private land. Most manufacturers of MHs have infill models specifically designed for city installations. If your state allows ââ¬Åmodularsââ¬
Brandon I didnââ¬â¢t look close enough the first time, good chance at least one of them is UF but the other one with the paper or other fill that appears to exiting from the sheath, that one I have doubts about.
That’s not UF.
ASTM Designation: C 926 Standard Specification for Application of Portland Cement-Based Plaster ANNEXES (Mandatory Information) A2. DESIGN CONSIDERATIONS A2.1.1 Sufficient slope on faces of plastered surfaces shall be provided to prevent water, snow, or ice from accumulating or standing. Air-entrained portland cement plaster provides improved resistance to freeze/thaw deterioration. Resistance to rain penetration is improved where plaster has been adequately densified during application and properly cured. Plaster shall not, however, be considered to be ââ¬Åwaterproof.ââ¬
California Business And Professions Code 7199. The time for commencement of a legal action for breach of duty arising from a home inspection report shall not exceed four years from the date of the inspection.
Mike For me thereââ¬â¢s no confusion between ââ¬ÅManufacturedââ¬
Many manufacturers of both manufactured and modular home use products similar to the one depicted in the photos. Note the widths available and that these rolls can be ordered doubled enable the manufacturer to underlay the roof in one operation. Image Insert: 145.51 KB Image Insert: 327.64 KB
