drw
Content Count
21 -
Community Reputation
0 NeutralAbout drw
Rank
New Member
Location
Occupation
Thanks guys. I have a pretty good idea what caused the crack to begin with. Several years ago they had 2 or 3 wild cherry trees removed. These trees were so big (trunks 8 - 10 feet across), that they brought a huge crane in to lift the sections of the trunk and place them on a truck. The crane made several passes not far from this side of the house. My guess was that this is when the hairline crack originally developed. I had him paint this wall a couple of years ago, being sure to fill the cracks with paint. The paint still completely fills the crack, so I don't think it has moved since.
Hi guys. I have moved on from the HI business, due to lack of business, but I have a friend who asked me a question I never thought about before. I can't imagine this having an affect, but he is really afraid it will. He has a son who is a pretty good basketball player. The son practices dribbling in the unfinished basement and also practices passing against the block wall. He throws the ball against the wall as hard as he can from various distances. There is already a small hairline horizontal crack on the wall he uses, but it was there before the son took up basketball. Do you think the
I did an inspection in mid-June. The house was occupied at the time of inspection. In the crawlspace I saw a piece of corroded galvanized drain piping. The exact words in my report were "REPAIR - Corrosion is present on the galvanized drain piping in the crawlspace. If this piece of piping were to rust through, the leak could go undetected for an extended period of time. I recommend replacement of this section of drain piping." Sure enough, this pipe leaked. The customer didn't get it fixed until after it leaked. The plumber told my customer that I missed a 4" hole and that the corros
IRC 602.8 says that "Fireblocking of cornices of a two-family dwelling is required at the line of dwelling unit separation." Would you interpret this to mean that the attic cannot be open across multi-family units? I cannot come up with a mental picture of "fireblocking of a cornice" in the context that I think of a cornice.
Sucks is a strong word. How about this... Wood siding is susceptible to moisture damage when it is not properly maintained. This is a limited visual examination of the home. The siding was checked for deterioration at a representative sampling of readily accessible locations on each wall.
Lets talk chimney height
drw replied to John Dirks Jr's topic in Fireplaces, Chimneys & Wood Burning Appliances
No. I am saying that a metal B-vent (double walled) can be AS LOW AS 1 foot. Even this will vary depending on the slope of the roof it is penetrating (the steeper the slope, the higher the termination point). My understanding is that for masonry chimneys, regardless of function, the 3-2-10 rule applies...the chimney must terminate at least 3 feet above the roof, and 2 feet higher than any part of the structure within 10 feet of it. -
Are you referring to masonry chimneys, or metal heating/water heating vents? B-vents can terminate as low as 1 foot above the roof. -
What to Say When all is Good
drw replied to randynavarro's topic in Report Writing and the Written Word
When I submitted inspections for review while joining one of the HI organizations, I failed in the first attempt because I did not list things that were OK. Example...One of the things the reviewer said I did wrong was that I did not inspect the vegetation. I replied that I did inspect the vegetation, but that the SOP for the organization only required reporting vegetation that would impact the structure, and this home had no vegetation that fell into that category. He answered that if I omit an indication that I inspected it and it was fine, then the client has no indication that I inspec -
Thank you. Very good article
One should never use "nosepicker" and "concoctions" in the same sentence...oops.
Sorry...Model # 867.763322
Does anyone know how to translate a Sears furnace serial # to find out a date of manufacture? As I understand it, Sears furnaces are not always built by the same manufacturer. The one I am interested in has a serial # H 93050209 and a manufacturer # 605418. Thanks in advance.
Check with the local utility. Some have lower rates for electrically heated homes (you may have to threaten to install propane or oil heat) or rebates on heat pump installation.
Can someone help me with the manufacture date of Carrier furnace model # 58ES150-12, serial # 16A02311. It's not 1958 is it? Thanks in advance.
Do any of you know if the "four inch sphere" rule for guardrails applies to fire escape stairs on a multi-tenant building? These are permanently fixed metal stairs, not the retractable ladder type fire escapes.
