Ponyboy
116 -
Events
Everything posted by Ponyboy
I am bringing this thread back to life and need more answers. I just inspected a condominium in a 1916 apartment building which was converted to condominiums and all of the the electrical and plumbing updated as part of the conversion. The conversion was performed prior to 2010, which was the previous time I was in this building. Gas clothes dryers where installed in the full bathrooms of all units as part of the condominium conversion. The laundry closet door has louver vents for make up air as stated in the PDF which Darren shared. However the closet door is located in the full bathroom which should be prohibited based on IRC M1701.4 as Mike Lamb posted. I called is out as a safety hazard in 2010, but now after reading this thread I am not clear if this a safety hazard. Options do exist to change the combustion air/make-up air source or convert to an electric clothes dryer. Any new opinion on this matter or updated code requirements?
Good question. The AHJ was not responding anymore to my clients request for a field inspection. The builder now only wants to hear from the AHJ, which is fine with me. I knew it was not the right position to be in, but I was trying to protect my clients and their interests.
Thanks guys! These are exactly the opinions I was looking for. I did remove myself from the discussion by stating this is my opinion and not a review of the building code. New construction builders have a statement in their contract with the buyers of not fixing anything which is not a code violation. They use this statement on any item they do not want to fix or address.
It seems to be in the code of immemorial custom. I do not have a code number to quote. I am going on how I was taught to build houses and common building practices in my area. This would be the first new construction or even five year old construction which a moisture break is not installed under the posts. I have observed capillary water damage to many floor posts which do not have a moisture break. I did send it back to the AHJ after receiving their statement but they now are not responding and will not send out an inspector. The buyer and builder are now looking to me to be judge and jury.
In an older house I would agree, but this is new construction and very expensive new construction. IMO the builder should correct the problem.
That style of connector is common practice with new construction in my area. I rarely see the metal base plates used.
I am have a discussion (argument) with the builder of a new construction I just inspected in Kirkland WA. What I said in my report - "Support posts are sitting directly on the concrete pier footings in the crawl space. The posts should rest in metal brackets above concrete piers or should be separated from the concrete below by impervious membranes such as composition shingle scraps. Even if the posts are made of treated wood, the cut ends may not have been field-treated, leaving little or no preservative at the post center." What the City of Kirkland building department said about this concern "As per permit code, the post must have a metal bracket or shingle, regardless of it being pressure treated or not." The builder still is arguing that it does not violate the code and will not repair this concern. He wants to have a conference call with me, the buyer and the RE agent to discuss it. Looking for advise on how to proceed to get the builder to perform this repair. Click to Enlarge 12.99 KB
I don't recall if it is hard wired or cord plugged. Does it make a difference?
In WA the water pressure is not supposed to be over 80 psi, per the plumbing code. A pressure regulator should be installed for any service pressures higher then 80 psi. The state inspection standards do not require home inspectors to check and report on water pressure. Check or not check is the question?
How many inspectors check and report on high water pressure?
Question, does a furnace in the crawl space require GFCI protection? Does it require surge protection? The house was built in 1982 and the furnace is five years old.
I emailed my picture and findings to DuraVent and spoke with technical support services at DuraVent. The installation does not conform with the manufactures instructions for installation of this vent system. Two options exist to repair this defect as stated by DuraVent technical support; 1) Replace the Ameri-Vent telescoping section with a DuraVent telescoping section or, 2) Install DuraVent male and female adapters to the Ameri-Vent section as Phillip had mentioned. Technical support recommends installing the DuraVent part for the best results. Now that I have proven my position we shall see what the seller does for repairs. This issue was not huge, but once I reported it I needed to back up my findings when challenged.
I should have investigated the listing of the telescoping vent section better. Thanks Mike! That is the section I thought was single wall. So the error with this vent is not using the same manufacturer through-out the vent assembly.
The furnace is located in a garage. B-vent exists above and below the single wall adapter.
I have a vent question. The gas vent on the pictured furnace starts with a DuraVent (B-vent), then a different single wall vent piece is installed and then back to DuraVent. The single wall piece is loose. I reported that the single wall vent should be replaced with a DuraVent piece. My understanding is you can not mix and match vent manufacturers parts. The furnace installation was inspected and approved by the local jurisdiction, (Bellevue WA). The seller will only change it if I can come up with a written document or a code saying it is an incorrect installation. Am I right or do I have egg on my face? Brad Click to Enlarge 74.64 KB
The second picture is of the gutter material.
This house is a flipper. I have a long list of other needed repairs. Was finished and has been sitting vacant for about a year. I was recommending a tear-off to my clients but needed some more justifications for the report. Do home inspectors sleep? Mike responded at 1:00 AM and Richard at 3:00 AM. I usually start at 5:00 AM. Thanks.
Need an opinion on this roof. New 30 year composition shingles were installed directly over an old torch-down roof, (3/12 pitch). The torch-down is buckled up in several areas and the new shingles are also buckled. The old torch-down still acts as built-in gutters and you can see the cracking in the old roofing material. I also found several areas of soft sheathing when the roof was walked. Will it last or should it be torn-off? Also, I would think the manufacturers warranty on the shingles would be void with this installation. I am supposed to be sent the roofing contractors warranty for the installation. Click to Enlarge 70.89 KB Click to Enlarge 106.15 KB
I like the Gas Company angle, I had not thought of that. I have an independent furnace expert going out to the buildings on Monday to render an opinion. Yes, about half the furnaces are original 1973. Some have been updated with minimal attempts to correct the combustion air and one was permitted in 2006 and installed correctly. My client will fix the problems if they have to but they are trying to get the seller to fix it first.
I am currently in a dispute over old gas furnaces and water heaters I found in the closets of duplex's and four-plex's I inspected in Thurston County WA. The Building/Fire Plans Examiner for Thurston county says they were legal when the buildings were built in 1973. Also, since the bedroom closet is full of the furnace and water heater, no cloths closet exists for the room. The building examiner is also saying this is a legal non conforming bedroom. Basically saying everything is ok. I called the installation as a safety hazard and recommended it be changed. I also included the fact of no closet. These rooms look like they were originally family rooms and have been advertised as bedrooms to get higher rents. People are sleeping in these rooms and they are packed with junk. Could hardly access the furnaces for inspection. I am trying to help my client do two things; 1) make these bedrooms safe for the occupants and, 2) get the seller of the property to do the repairs. Typical for a commercial property the seller is unwilling to do repairs which are not code violations. Any ideas or codes would be appreciated. Click to Enlarge 16.1 KB
Building Permit Research
Ponyboy replied to mgbinspect's topic in Report Writing and the Written Word
Anyone else using this service? All of my clients or the RE agents seem to able to find the permit information they need for a property. They have contacted me several times and I have expressed that I am not interested but they keep calling. Today I got a coffee mug in the mail with more promotional material. Seams like most of the fee they charge goes into their marking machine. -
I just read through the Wirsbo installation guide and it only talks about no DIRECT sunlight exposure related to storage. No mention of INDIRECT sunlight exposure related to the installed tubing. It further notes an angle support with chrome sleeve for angle stops as optional for a finished appearance at fixtures. I also found an article from Vanguard stating INDIRECT sunlight will not harm their product. Based on this information having PEX exposed at angle stops inside of the house appears to be an acceptable installation practice.
Most PEX installations I see the piping is run out of the wall and the shut-off valve is connected to the pipe (toilets and sinks). A small portion of the PEX is exposed inside of the house. Only on a few installations do I see copper installed at the end of the run and a shut-off valve installed onto the copper. I have never called this condition out as a problem. I do not recall it ever being mentioned at any plumbing seminar I have attended.
My client from Pennsylvania is moving to Washington and is concerned about the PEX water piping being exposed to sunlight at any shut-off valves or anywhere in the house. I have not heard of any sunlight problems with PEX. The house is new construction in a retirement development in Redmond. Anybody heard of this type of problem?
I also found a pesky squirrel last week. He had chewed a hole through the siding at the very top of the gable of a three story house. Click to Enlarge 23.14 KB The squirrel had caused significant damage to the insulation and cardboard baffles at the eave vents. This house was only 2 years old. Click to Enlarge 26.16 KB
