I agree with Scott, the decision to use push piers versus helical is a matter of economics. If bedrock is fairly shallow push piers are typically used, deeper soils require helical piers. Be skeptical if the engineer that designed them works for the foundation company or was referred by the company. Most of these foundations companies install way more piers than needed, remember the more they use the more they make. Most walkout basements are partially supported on fill dirt that was poorly compacted causing the back half to settle. So only the back half would typically need piers. If they want to pier the entire perimeter of the foundation, get a second opinion from an independent engineer. Around here those piers are about $1000 each, of if the engineer reduced the number of required piers by one you saved money. Also the typical spacing between piers is about 6 to 8 feet.
