I often run into houses where people paint (not high temp paint) their brick fireplace faces directly above and to the sides of the fireplace opening. I consider this improper, but am not really sure whether it will hurt anything.
What do you all say when you run into this, if anything?
Thanks.
Never gave it any thought. I can't really think of how it could be an issue. If you had a fire hot enough to catch the dried paint on fire, you're going to have bigger problems to worry about!
Thanks for the reply Scott.
I've just always told people that it's a bad idea, but that it will probably never actually cause a problem.
The NFPA requires a min. 6" clearance above the fireplace opening to any combustible material that sticks out less than 1.5"-- I would think this would technically apply.
The think that it was elastomeric paint, but it could have been latex. The exterior brick was painted the same color, so I figure they just moved on inside with the same stuff. I think it's typically latex that I see, but don't always pay much attention.
