I have a Protimeter SM and here is a good book on moisture and meter readings that Protimeter engineers recommended. "Dampness in Buildings Second Edition by T.A. Oxley and E.G. Gobert" Costs about $35.00
Donald, I do not mine, for you saw the whole PEX setup. I should have asked if the downward bend was fasten to a stud, but I figure it was because of your experience and you not asking in your question. End of subject for me.
I understand where you are coming from. Have had the same problems in the past with builders and I am sure I will experience it again in the future. Thank you
Chris; Like they say " You have express your opinion and I have express mine". After reading again the General Recommendation - Comment #3 "Use clamps or straps at tubing bends directly from connections", reading the Instruction Guide page 7 (At your PEX site) and looking at the photo again My opinion remains the same. "The holes in the studs are acting as a strap"
I agree with Richard about no value support. Cris: The way I see the installation, the holes in the studs are acting as a strap. The maximun horizontal spacing for pipe support for PB, PE-AL-PE, PEX, PEX-AL-PEX is 32"
The labeling of the neutral with the white tape would not fly in our City or County (white, gray, white stripe only), also can not see the other end in the so called gutter.
Jim Morrison web site is right. Like they say ââ¬ÅFirst, test the balance of the door (see "Testing and Maintaining the Garage Door."). If the door is properly balanced, then proceed" It sounds like everyone does not do Step Number 1. I have always instructed our Inspectors to check the balance of the overhead door before testing the operator. The 2X4 method works better because the hand method can sometimes unravel the wire on the spool. The "Down Force Adjustment Screw" is used to counteract the tension on the springs after the balance point, so that the door can be closed.
I have never heard of that method of construction for a slab. I have used visqueen on top of a slab for curing instead of a chemical spray. Tim Do you have any pictures of a slab prior to placing the flooring material with this method of construction?
If you ducting is in the attic, I would add more insulation over the ducting (Ducting is either a R4 or R8) instead of cooling your attic. Up here they have a R40 in the attic. Manufacture homes have a R50. Blow-in insulation is cheap return on your investment.
I have seen 30 days to 6 months, just depends on the product. Here is from Grace. Installation of the roof covering can proceed immediately following underlayment application. Grace Tri-Flex 30 cannot be used as a primary roof covering. The product is not designed for permanent outdoor exposure. The installation of the final roof covering should take place within 6 months. Mike link also has 6 months. Chris Take a look at the back side of the label and it most likely will tell you the exposure time for that product.
