Marc The various specs try to cover every scenario. Without a drain plan this assembly can be very unforgiving over time and some of the problem I see have developed in a short amount of time. I have looked at three in the last six months that were less than a year old. As was pointed out in an earlier post this stone assembly is basically a stucco with rocks in the surface. I do not see many that use the weep screeds or casing beads. Generally it has the WRB over the sheathing, the wire mesh, and the faux stone. This is all applied in a hurried manner without regard to some of the finer detail required to make the assembly drain. I don't care how many layer of paper you put on if the assembly fills up the liner will eventually leak. on the repairs I have been involved it goes this way. Wall sheathing, WRB, layer of grade D, metal accessories, Delta dry or MTI, metal lath, scratch coat, rocks. This allows any incidental moisture to have a clear path to drain. Page 6 MVMA left side last paragraph: Rainscreen Drainage Plane Systems (Optional), should be mandatory. Delta Dry http://www.cosella-dorken.com/bvf-ca-en ... ts/dry.php MTI http://www.mtidry.com/
