I remind people to consider the following relative to K&T: -No 'equipment ground wire' present. ('less safe')(have boiler plate about what a ground fault is). -Rubberized cloth insulative jacket is surely starting to get brittle (find some examples, point them out in photos). -Meant to be 'free-standing in air (except where run through tubes...). Point out insulation packed around it... mention that some insulation installers actually will require it be removed prior to installing insulation. (some...not all). -Point that by this time (approximately 100 years) the building has probably had renovations over time which increase chances of ground faults to occur (pipes run in chases, wires fished through spaces, 'stuff' (K&T) in walls and ceilings have higher chance of having been moved out of original intended position. The chances for renovations over time to have damaged insulation is likely higher. -Mention that GFCI receptacles can be installed on K&T, but what if as soon as you do that and you energize the circuit, the GFCI trips? Now you have to find the GF... -Some insurers will not insure a property that has knob and tube wiring. Yep....since 9-11. I also mention the thicker gauge wire, etc. It all leads to considering 'pro-active replacement' in general. I also tell them that others may disagree. I find that in most basements (like the one yesterday in a circa 1840 home) I can find at least one or two defects (in yesterday's case, I found a 'hot' K&T conductor fallen off of its knob, a severed, unterminated, live K&T conductor, K&T running against/on metal pipes and boxes and worn-away insulative jacket with exposed conductor. Rarely do I find a 'pristine' condition installation though in some uninsulated attics, I have found some installations that looked almost as good as the day it was installed (but I didn't 'flex' the jackets...). I have an antique book called "Electrical Railways" that shows how these installations were supposed to be installed at that time. They make good points about proximity to metal, free-standing in air, etc. In the infancy of the electrical distribution system, there were many ground-fault-related fires out there... Now with 'equipment grounds', 'bonding', GFCI, AFCI, the risk of fires due to ground faults and arcing is less. "Less is more" (safe..).
