This wire over-heated...wasn't from corrosion. If you look closely at the end of the white wire insulation (may be hard to see well), it turned very brown from the heat, just like you'd see the end of a neutral wire turn brown at a bus bar connection that over-heated from sharing two hots on the same phase. In person, it is very obvious this was from heat. Lightning? Don't know. This was the only thing with damage...nothing in the panelboard like I'd expect from lightning. Again, neighbor said Sparkys have been to the home before 'cause of "problems"...don't know the nature of the "problems"...vacant house, neighbors hearsay. Jim...I posted on ASHI about a year ago about current bleeding from ground to water pipe. I even posted a picture of my ammeter with a record finding of 23 amperes in the pipe! Have also seen current run into gas pipe that was lying on the water pipe. From the ground?...Yes...I disconnect the ground, current in pipe disappears. Some local utility guy said the older utility co. infrastructure is undersized for the tear-downs(very common around CHi-Town) and resulting service size increases in the new, bigger homes...the utility co. older neutral is undersized, and can't handle all (increased) return current...thus, it bleeds to ground & into house water pipe. Would love to hear Dougs thoughts.
