bradfeldt
    22
    Home Inspector
bradfeldt's Achievements
New Member
New Member (2/5)
  1. You see that all of the time in MN, usually with small black stains around the nail penetration. From the lack of the stains I would say that either this is the first winter this house has been through or something with the ventilation / vapor barrier has changed dramatically recently.
  2. Our software works flawlessly to insert pictures into the finished report. The only downside is that they are at the end of the report. For us, it is a matter of uploading the photos, clicking a button that 1. resizes the image (both pixels and file size) 2. displays it and asks if you want it in the report (that way you don't have to review them on the camera.) 3. Inserts the photo and asks for a caption. If you are a decent typist it takes about an additional ten seconds a photo.
  3. We always remove the panelboard cover (and all sub-panel covers.) All GFCI's are tested using both the built in test button and a three light tester (go ahead, start railing on me for not using a Sure-test.) We will not operate any breakers or pull any fuse blocks (just ask Kurt M. why you don't pull fuse blocks.) If a breaker is off we assume it is off for a reason.
  4. bradfeldt
    GE Date?
    I have never understood the necessity of HI's to give an exact age. This would be very simple for me: 1. Average furnace lasts 20 years. 2. House was built in '75 therefore the furnace is either 29 years old or 9 years old. 3. The model # doesn't appear in the Preston manual. 4. The furnace looks old - possibly original. 5. Every HI should know the difference in appearance between a 29 year old furnace and a 9 year old furnace. Obvious conclusion (at least to me:) The furance has outlived its usefull life and replacement should be planned for the very near future.
  5. Chris, The Snifit is for personal protection, not for testing gas appliances. It is meant to alert you when you are entering an area with hig CO levels.
  6. We always used the Monoxor II's in the past but have switched to the Monoxor III's. They run on AA instead of D batteries, have a "hold" display button, and the batteries seem to last longer. We experimented with the Fyrite Pro but immediately gave up due to broken connections on the moisture filter.
  7. What is an ILLUMINATING appliance?
  8. Could it be a back drafting water heater that is spilling excessive moisture into the home after the family's morning showers? Coupled with not running exhaust fans you could have a signifcant amount of moisture that would dissipitate during the day time when the water heater is not running.
  9. Is it condensation on the glass or is it between the panes of glass? It sounds more like a failed seal.
  10. Painting and replacing floor coverings is about the only options left. Or else you can find a scent that is acceptable!
  11. Ok, let me rephrase. Although shingle manufactures HAVE COME out with algea resistant products...
  12. Turning water heaters all of the way off can allow bacteria to grow inside of them. For this reason manufacturers have provided a vacation setting. It really no different than "low."
  13. Although shingle manufactures are coming out with algea resistant products, they are pretty much useless. Read the fine print on the warranty and you will find they only warranty the algae resistance for 10-12 years - about the same time you really start to see the staining.
  14. It took me 25 minutes and I scored a 72. Having said that, I received a 0 in the fireplace category. Overall, it is not bad. A few suggestions: 1. If you are going to include pictures they should be of better quality. 2. If I hadn't been moderating the forum I would not have known that some questions have multiple answers. 3. Typos on some questions. 4. Notify users which answers are incorrect.
  15. Gary, please add me to the safe access list. matt@prelook.com thanks,
