Rob Amaral Posted November 27, 2014 Report Posted November 27, 2014 You know.. you plod along... and then.. the entertainment begins... .. That is a load-carrying 2x field-laminated solid wood beam... Click to Enlarge 50.15 KB
Rob Amaral Posted November 27, 2014 Author Report Posted November 27, 2014 Not 1, not 2, not 3.. FOUR chain-saws...
Erby Posted November 27, 2014 Report Posted November 27, 2014 You have to admit, Rob. It is a unique solution to a common problem!
John Kogel Posted November 28, 2014 Report Posted November 28, 2014 That might have been a real head-scratcher without the saws there. Can the beam be fixed with wood plugs and glue?
Ben H Posted November 28, 2014 Report Posted November 28, 2014 I want to know if each respective blade was used to cut the hole it rest in.
