crusty Posted July 14, 2004 Report Share Posted July 14, 2004 I have always operated under the premises "if it stinks, it's probably rotten." This looks problematic to me. My gut tells me that these two vent terminations will interfere with each other. They serve 2 different factory built fireplaces, one of which now has gas logs installed. I can find nothing in the materials I have or any code reference that addresses this but I keep thinking one may interfere with the draft from the other. If it were just smoke the problem would be apparent but we are dealing with a gas appliance as well. Of course the installation manual was not present. Help? Download Attachment: 141_4156.JPG 43.86 KB Link to comment Share on other sites More sharing options...
Terence McCann Posted July 14, 2004 Report Share Posted July 14, 2004 As long as the rest of the code conditions were met for solid fuel appliance then I would think that just raising one a few feet above the other should suffice, easy fix. In real life I don't think it would effect the draft. Link to comment Share on other sites More sharing options...
kurt Posted July 14, 2004 Report Share Posted July 14, 2004 This came up on the ASHI board in years past several times. Michael Casey, whose opinions I respect immensely in matters of mechanical systems, indicated that there is no problem w/ this sort of flue arrangement. At that time, he cited a number of references that I have since lost or forgotten; since it was his opine, I take it at face value. Casey said it's OK, it must be OK. You are operating under the impression that it stinks; maybe it doesn't. You have not been able to find any documentation stating it is unsatisfactory, so the prevailing evidence is that it is OK, no? Link to comment Share on other sites More sharing options...
crusty Posted July 14, 2004 Author Report Share Posted July 14, 2004 Michael was my instructor when I went through ITA. I have known him for years and respect his opinions without question. If he opines, I agree, automatic. Thanks Kurt. Link to comment Share on other sites More sharing options...
