stuccoman
    59
Everything posted by stuccoman
  1. It is not only a stucco thing! Most window mfgrs. have it in their installation specs no matter what the cladding is.
  2. No backer rod and sealant joints around the windows. ASTM spec and most window mfgr. spec. Stucco before the sheet rock is hung is a good way to have alot more cracks. Not only from the nailing of the rock but the house adjusting to the weight. 2 layers of moisture barrier as others have mentioned. Control joints/expansion joints. The basecote looks real thin!
  3. http://www.mnlath-plaster.com/listing/S ... Constr.pdf Minn. has it figured out.
  4. Look at page # 5 If they are not installed to the mfgrs. specs when they leak the homeowners insurance will not pay to fix things. http://www.pella.com/lowes_thermastar/t ... pdf#search
  5. It is not just for use when stucco is there it is all claddings. Look at page# 5 http://www.pella.com/lowes_thermastar/t ... pdf#search
  6. Here is another one. http://www.mnlath-plaster.com/listing/S ... Constr.pdf And here is thier check list. http://www.mnlath-plaster.com/listing/S ... cklist.pdf
  7. Another install link. http://www.robinsonbrick.com/products/r ... lGuide.pdf
  8. http://buildscanir.com/index.php
  9. I see some more leaky houses on the horizon!
  10. The ES report http://www.icc-es.org/reports/pdf_files ... R-1474.pdf
  11. I wonder what happens to it if it comes in contact with cement/mortar.
  12. It says not to use it with stucco and EIfs. And with brick it only needs a 1/2 inch airspace? And on down a few pages it gets into the flashing detais!
  13. Read about half way down on page #2 http://huberwood.com/zip/zipwall/pdfs/2 ... %2040D.pdf
  14. What do you think of it Mike? For stucco application to meet ASTM specs wouldn't there still need to be another layer? And they did not show flashing or window and door installation.
  15. Moisture barrier is good practice but it does not have to be tyvek. Imo
  16. In your third picture it looks like there is a wire mesh of some kind. It looks like 3 cote work with some thin spots!
  17. What about when the carpenters leave off the flashing? http://www.badstucco.com/phpbb/viewtopic.php?t=574
  18. Bad window installation and lax codes inspections/enforcment.
  19. http://www.badstucco.com/phpbb/viewtopic.php?t=570
  20. It goes on like a tile roof. A starter strip and screews or nails no mortar.
  21. It could work but it is wrong. Gimme a call 913-208-7090 Carl http://www.badstucco.com As for the installation as per ASTM it is wrong.
  22. Chris, Does this help? I have a call into the rep in kansas city. http://www.icc-es.org/reports/pdf_files ... S/3899.pdf
  23. Mike You are 100 and 10% right. Just like with the kickout diverters. All house with what ever cladding need them.
  24. The life of a stucco job can be shortened when the windows are installed in this fashion. http://www.badstucco.com/phpbb/viewtopic.php?t=543
  25. There is alot of stucco being done now that will not last as long as the stucco in question has for a number of reasons.
