jon_ran
    127
Everything posted by jon_ran
  1. Look for a wholesale distributor. We have one about 30 miles north of Indianapolis that sales to the general public. As far as the sizing goes, unless your present equipment was not sized correctly you shouldn't go wrong with duplicating what you already have. If you have an old low efficiency, you may be able to downsize slightly if you go with a higher efficiency furnace. As far as the a/c goes, resist the urge to go large thinking that it will cool better. A unit too large will reduce the temperature to satisfy the thermostat fairly quickly and shut off (short cycle). This reduces the amount of moisture laden air that flows across the evaporator coil and will not remove the humidity from the home that is needed to make it feel comfortable. You can step up the evaporator coil one size to further improve the efficiency of the system, but you can not step it down ( a 2 ton coil can be used on a 1-1/2 ton condensor, but a 1-1/2 ton coil can not be used with a 2 ton condensor). Installation is fairly simple provided that you have the equipment and ability to either braze or silver solder (make sure that you keep the valves cool). DO NOT try to use soft solder, you will blow the lines off. The condensing unit comes charged with enough freon for a 25' line set. You can buy a cheap set of guages and rent a vacuum pump.
  2. Short Answer... With enough sheet metal, you can physically match the evaporator coil up to any size furnace that you want to. The evaporator coil is what gets installed at the furnace. Long answer... One question is, will you have enough air flow across the coil? A 5 ton unit is really a huge unit and unless you have a HUGE house, it will be too large. It may cool the home down, but not run long enough to turn the air over and remove the humidity. Ducts may be too small, cooler air is more dense and harder to push through the ducts. Correct answer... Have a HVAC contractor set you straight. You will need one anyway unless you are competent with silver solder and (at minimum) MAPP gas torches, electrical systems, thermostat replacement, etc. Not to mention, the unit will need to have the refrigerant recovered prior to removal from your friends and re-charged at your home.
  3. I was busy once on a remodeling project at home and sent my wife to Lowe's for junction boxes, cover plates and cable clamps. She doesn't know one from another so I told her to get the sales associate to help her. Shortly after getting to the store she calls me bacause the person at the stoor did not know what she was talking about. I tried to tell him what I wanted and after about 3 minutes told him that he needed to find someone else who knows electrical items to help her but he said that he was the only one there and assured me that he could get her what I needed. She arrived back home with outlet boxes, junction box cover plates and cable clamps.
  4. Doesn't matter when they were required by code. They should be installed now to improve safety when navigating these steps. What was the height of those risers, they look awfully short. What's up with the vents under the porch slab?
  5. Not only is it unsafe, but it is also UGLY!
  6. Unless you have physically piped the water supply to the bottom of the tanks, I would put the dip tube back in. Make sure that the tpr's are in place and operational. This will help with temperature control in case it gets too hot. Another option would be to place them at a level higher than the heat source and take advantage of thermo siphoning using copper tubing. Google "thermo siphoning" for more info. Place a pan under them, move the assembly to another area of the home if you are worried about looks. In reality, this isn't going to be pretty anyway. BTW, I did this several years ago by placing an old 20gal. electric heater tank (with the element removed) on top of my wood burning furnace. The furnace was heavily jacketed so it was actually like placing it on top of the plenum instead of the burner wall, which protected it from too much heat. It worked great as I would have to use at least 20 gallons of hot water before I would introduce cold water into my gas water heater.
  7. The home has been rewired and the power for that area is coming from somewhere other than that panel.
  8. I am always open to constructive criticism and will change my boiler to reflect that I recommend either replacement of this panel or an in depth evaluation by a licensed electrician who has knowledge and experience with FPE panels. I still can not see demanding replacement if it can be effectively made to perform safely. That is almost like saying that every pit bull needs to be euthanized at birth due to the potential of another pit bull attacking and maiming a child.
  9. Umm.......Les, see the quote below from the original statement above.
  10. I do not provide free re-inspections, nor do I spend money anymore on brochures. They usually end up in the trash. Good looking, professional business cards and thorough inspections will get you more business than brochures, IMO.
  11. You have to remember that there is a failure rate in everything mechanical. Whether it is a FPE panel or a Square D, there is the possibility that the breakers will not trip when overloaded, there is just a much higher occurance in FPE panels. Remember that not all of the FPE breakers are faulty, just the majority of them. If all of the breakers do trip at the stated load (unlikely), they are not an issue. Unless I see signs that that breakers have not tripped (overheated breaker, panel, wires, etc.) I can not tell by looking at them if they will operate as they are supposed to. I have had some electricians state that they are an issue and recommend replacement and others state that they are not a problem. If there is evidence of issues, it is a no-brainer. My statement is not inadequate... I stated that there is a very high failure rate with this type of panel that could cause an electrical fire. My statement is not deceptive... Again, there is a very high failure rate with this type of panel that could cause an electrical fire. My statement does meet a very high standard of care... Again and again, there is a very high failure rate with this type of panel that could cause an electrical fire. I recommend you consult a licensed electrician for an in depth evaluation. If somebody can not read that statement and realize that there are issues with these panels in general that may cause a fire, I can not help ignorance. Remember that we are not the house police. Unless there is an obvious issue, how can you demand that the item be replaced. If the electrician says that the panel is fine, I have performed my duty and made my client aware of the potential hazard and recommend somebody more qualified than I determine whether it is safe or not. The CPSC concluded their last evaluation of FPE panels in 1983 and stated that "failures of these FPE breakers to comply with certain UL calibration requirements do not create a hazard in the household environment. It is Reliance's position that FPE breakers will trip reliably at most overload levels unless the breakers have been operated in a repetitive, abusive manner that should not occur during residential use." www.cpsc.gov/CPSCPUB/PREREL/prhtml83/83008.html 1. If I find aluminum wiring, I notify my client of the potential fire hazard associated with aluminum wiring and recommend that the circuits be evaluated by a licensed electrician to determine if connections were made correctly and repair as necessary. 2. If I find PB or ABS piping with no signs of failure, all that I can do is notify the client of potential issues and recommend evaluation and replacement consideration. 3. If I inspect a 40 year old furnace that is properly installed, puts out heat and has no CO or other issues, I can not demand that it be replaced. I notify my client that it is way beyond it's life expectancy and could need replacement at any time. 4. If I find a 30 year 3 tab roof on a home with all of the shingles in tact and no leaks, I can not demand that it be replaced with a new roof. I notify my client that it is past it's life expectancy and recommend that it be pro-actively replaced in the near future, before leaks develop.id="blue"> Should my client as for any of the above items to be replaced before they will buy the home that is between them and the seller, not me. I can not demand replacement of anything. In conclusion..... Would I want a FPE panel in my home? NO Do I recommend that anyone keep a FPE panel in their home? NO Do I tell my client that their panel and the disconnects inside of it are safe to use? NO Did I present my client with enough information and recommend the appropriate resource to help them make an informed decision about keeping or replacing the panel? YOU BET I DID!
  12. Unless I see signs of overheated wiring/breakers, I would not automatically recommend a replacement of the FPE panel. I do place a statement in the report about the issues surrounding these panels and recommend that the entire panel be evaluated by a licensed electrician to determine what actions should be taken. This notifies the client about potential issues and places the liability on the electrician, should he/she say that it is fine and doesn't need replacement. I do let the client know that if I were buying the home, I would WANT to replace the panel, but unless an issue was found by the electrician, replacement may not be necessary. As far as the light goes, an overheated fixture does not mean that the breaker failed to trip. It could have been connected to a 30 amp disconnect and burned at 20 amps. Below is my standard statement for a FPE panel: ?Monitor, Possible Major Concern: This home has a Federal Pacific electric service panel which, historically, has a possibility that the circuit breakers may not trip even when their amperage rating has been greatly exceeded. In some tests, up to 74% of the breakers failed to trip at 135% of their rated current with several failing to trip at over 200% of their rated current. Should this happen, an electrical fire could likely occur. The only method of testing individual breakers would be to perform load tests. Opinions about this panel vary among licensed electricians, but I recommend you consult a licensed electrician for an in depth evaluation, load testing and correction if necessary.
  13. $480 got me a year listing in the yellow book with an on-line listing with links to my web site. Currently #1 on the list when searching for Indianapolis Home Inspection, # 9 when searching for Indianapolis Home Inspector. For $1,000 I believe that I could have gotten guaranteed placement in the top 3, but I'm not disappointed in my position so far. Yeah, I know that most people who use the yellow pages are price shopping, but it does give me visibility to those looking in the yellow book or on-line and 2 inspections/year would pay for it.
  14. I wouldn't have a problem doing something like that, provided I didn't have to pay $1,000. I have given enough realtor presentations to tell you that, unless you are a smooth talking-closer friendly inspector, you will most likely not do as well as you think. I am not against giving presentations and such to others as a promotion for you business, but I doubt that it would be worth the the $1200-1300 that I would end up spending if I were in that position. I know that 4-5 inspections would recover that expense, but I just haven't had much success and wouldn't do more than donuts or maybe pizza.
  15. Foundation stabilization to an earth anchor in the yard.
  16. In Indiana, they are not sales taxable. We are providing a service and not selling an item. The report is the final product of our service, but it is still not a product. If we were, say, in the minibarn business and sold completed mini-barns built on your lot, they would be subject to sales tax. Check with your local revenue department to know for sure.
  17. A quote from a fireplace expert on another board: "NFPA 54 requires within 6 feet and "accessible" IRC requires "accessible" within 6 feet. If over 6 feet, must meet 3 criteria: readily accessible serve only that one appliance be labeled what it serves"
  18. Could you see under that 1X4? It is either "something" rated or "something" impregnated.
  19. Concrete does 2 things after it has been poured, it gets hard and it cracks. As Kurt said, you have expansive soil conditions there that we do not have here so you won't be able to get a real good answer from us. Minor cracks are usually of no concern, as concrete is expected to crack. A slab crack with displacement (ie. surface differences) or slab cracks that are drifting apart would not be considered minor. Carpet and thick padding can hide lots of things and unless the crack is stepped on to feel the difference, it may not be discovered. As you said, you didn't know about it until you stepped on it without shoes. I don't want it to sound like I am trying to defend the inspector and say that he is not at fault, he may be, it depends on the circumstances. There is a good chance that the sellers knew about this and purposely hid it under the carpet. People are very creative at trying to hide defects. There is also a chance that they thought that they were minor cracks as they disclosed. The cracks that were filled could have been done by the carpet installer without the owners knowledge.
  20. A damaged or non-existant crown at the chimney? Damaged masonry on the chase?
  21. I had an engineer tell me that (for damaged webbing) sistering another board of the same size next to it and through bolting it would be an acceptable repair. Seems to me that it may work for the top chord too.
  22. Thanks for that publication. I guess that it would make sense that a false negative for asbestos would be highly likely. Time to modify my boiler...
  23. You might want to have that tested for asbestos before you start looking for quotes for removal. Just because it is vermiculite does not necessarily mean that it does contain asbestos, only that it could. Have no clue about removal costs.
  24. You can ALWAYS differentiate the main by determining where the SEC is attached. The wires coming off of the tap with the main do not have any protection. This is a fire hazard that must be recommended for repair. Upgrading the panel would be a good option.
  25. Great big double trap, not allowed.
