adair
    24
Everything posted by adair
  1. JG zaxly what i thought my daughter has had a snoopy collection w/clothing changes going back to the late 70s early 80's she wasn't impressed w/ur choice of wardrobe
  2. no disrespect intended what exactly is your image of?
  3. this is from the interweb w/nec branch and feeder sections cited https://electrical-engineering-portal.com/download-center/books-and-guides/electrical-engineering/voltage-drop
  4. way2 low imo YMMV https://up.codes/s/overhead-service-and-service-entrance-conductor-installation
  5. yes @ all panes only 60" AFF – Above Finish Floor or 60" away from tub shower edge wouldn't
  6. all i can add is should be protected from freezing and signage is code required for nonpotable
  7. nope, only to the smallest of bugs she caught supper, i think it's a fruitfly
  8. finally found her next to her larger egg sac the size of a #2 pencil lead click to enlarge
  9. removed
  10. sure appears to be a mfr defect unless they were hand sealed for whatever reason with an improper product...did you try to lift any for better view of sealant possibly Certainteed Grand Manor http://www.certainteed.com/products/roo ... ial/308581 i've emailed mfr the image(s) for clients & owners & requested a company rep view on site to prescribe a remedy
  11. yes & also use v-grip clamp so ladder stays there until i get back to it...windy days & rough neighborhoods Click to Enlarge 31.53 KB
  12. adair
    shingle info
    anyone have any info (name, brand) on these? Click to Enlarge 104.16 KB
  13. proper bonding of CSST has not CURED this material for lightning strike resistance and subsequent death causing fire http://www.nbcdfw.com/investigations/Fi ... 45981.html http://www.nbcdfw.com/investigations/Sa ... 14091.html
  14. I think Joe meant to post this link BTW he was the originator of getting this info out to all of us
  15. Mike, You and any others are welcome. Joe Tedesco (sp) posted it on another forum/BB Good info is welcome from all sources. imo
  16. http://tnblnx3.tnb.com/emAlbum/albums// ... _lr_bm.pdf
  17. This is a You Tube video of a news team investigation of the tragic death of a little boy who'd died when he touched a metal garage door and was electrocuted. Investigation determined that the garage, which was a recent addition, had been improperly wired. [utube]http://www.youtube.com/watch?v=yiZFjRA_Gs4[/utube]
  18. Brian, Maybe time to upgrade Adobe reader. http://www.adobe.com/products/acrobat/readstep2.html
  19. http://216.122.22.11/FetchDocument.aspx ... 50c39ad3aa Is a pdf file as Scott said off of the Rheem/Rudd site. Spec data with a list of their breaker sizing for 10 of their units just for an example. If you'd like to do your own search at the Rheem/Rudd site: http://www.rheem.com/Entrance/index3.html Works for most MFG. other than Trane. I guess Trane thinks their units are too COOL.
  20. Rheem/Rhudd does have installation specs online. Page 5 has breaker/disconnect table http://216.122.22.11/FetchDocument.aspx ... 50c39ad3aa
  21. Brian, Thanks for the input and need for further necessary info. Good call. It's on a slab foundation. This is primo clear heartwood cedar and is a hermetically sealed closet with a self closing door.
  22. This closet was built in 1994 with 1x4 tongue and groove smooth sanded planks. It is 4'x 6' and stinks to high heaven. No apparent signs of moisture intrusion or any forms of dead bodies or other life forms. Seller says it's been this way for a while. Wont store anything in it. Buyer would like a resonable solution short of complete tear out and replacement or surface sealant, which defeats the purpose of having a cedar closet. Any help or suggestions would be appreciated.
  23. Howdy Folks, Are any of you familiar with or using this tester as part of your inspection process? http://www.ecmweb.com/ar/electric_arc_f ... und_fault/
