Scorpio008 Posted October 12, 2006 Report Share Posted October 12, 2006 I just tring to get some tools as a newbie. Just wondering about this meter since it does both gas and co. instead of have 2 meters.(1 gas & 1 co detector). That meter is $300.00. It's 2 in one. just curious has anyone tried it yet. If not then I would have to spend more money and go w/ the Bacharach Jr for gas and the UEI C071. These is pushing $400.00 for both. Quote Link to comment Share on other sites More sharing options...
jon_ran Posted October 31, 2006 Report Share Posted October 31, 2006 I have the TPI775 in addition to a Tiff 8800 and Tiff 8800A. I have not had any problems with the TPI, but have found that I don't use it as much as I thought I would. The flamable gas detection head is much bigger than the Tiff and therefore remains farther away from the pipe/fittings, but it does work. Plus, the CO detector is built into the back of the body, not on the wand as one would think. If I had it to do over, I probably would have bought the Bacarach (??spelling??)and added it to the Tiff. I guess that if I didn't have the Tiff, I would use the TPI exclusively. One caution, since it has a push button power switch, it does hav a tendancy of turning itself on. Always carry extra batteries. Quote Link to comment Share on other sites More sharing options...
Scottpat Posted October 31, 2006 Report Share Posted October 31, 2006 Don't waste you money on a gas detector. I as most inspectors who have been doing this for awhile have ours sitting on a shelf. Use the one on the front of your face. Plumbers putty will set off a gas detector so will bad breath and if you have lunch at Ponchos Buffet, it will be useless. Just my two cents. Quote Link to comment Share on other sites More sharing options...
kurt Posted October 31, 2006 Report Share Posted October 31, 2006 Count me in as one who uses his nose for gas leaks. I haven't used my TIFF in 8 years. Quote Link to comment Share on other sites More sharing options...
Mike Lamb Posted October 31, 2006 Report Share Posted October 31, 2006 I also try to carry a back-up nose. Yesterday, I thought I smelled a leak and the RE agent and my client couldn't smell anything. On my second smell, I couldn't either. So I reconsidered. It might have been my breath. Quote Link to comment Share on other sites More sharing options...
homnspector Posted November 1, 2006 Report Share Posted November 1, 2006 I do use the gas detector occasionally when I smell gas but can't figure where it is coming from, spray stuff actually works just as well or better. When I started out, I bought a Tiff with the understanding that it detected CO. It does, in very high concentrations, it detects any carbon based gas but doesn't tell you what it is detecting. I don't know about the 775 but don't get fooled. My feeling about gas detectors is the smaller the better. Anything big will end up collecting dust in the truck. Quote Link to comment Share on other sites More sharing options...
sixgun95 Posted April 27, 2007 Report Share Posted April 27, 2007 I have the 775, it works as advertised. Quote Link to comment Share on other sites More sharing options...
Eric B Posted May 1, 2007 Report Share Posted May 1, 2007 My Tiff has not been relegated to the shelf yet. It's faster than my nose and reaches pipes better. If I have a question about a leak I use Sherlock Leak Detector, same solution our local utility uses. If the leak will not cause bubbles to form the gas company will not take issue with it. Regardless of how much the meter screams. Quote Link to comment Share on other sites More sharing options...
