sbrooten
    34
Everything posted by sbrooten
  1. Chris, I don't think that any regs regarding protecting the electrical line would change because the appliance is located in a closet. As for being anchored, that is not a national requirement. It is generally (to my knowledge) only required in seismic areas and regs would be dependent on local rules. Probably the best thing to do is to check with the AHJ.
  2. Okay, how about this... The 167 mph wind blows through the area and cheesy fiberglass/plastic panels blow off. Mr. Do-It-Yourselfer gets pissed, goes down to Home Depot and buys plywood and shingles so the d----- thing won't blow off again. Now I see a big problem, as the load isn't transferred to the wall. I won't count on things staying as they are now. I will point it out and let the chips fall where they may.
  3. I've been using 3D for several years, and have not had any support issues with them. Actually, in the time I've had the software (over 5 years) I've only had to contact them for support once or twice a year, and the issues have been solved. I will admit that the last person I talked to ( about 3 months ago) was a little curt on the phone, but her support was right on. I can live with bad manners, but I can't live without functional software. Just MHO...
  4. I have to agree with Mike. The primary source of foundation issues in my area is poor site drainage. Nearly every report I write indicates that site drainage should be improved. As Mike said, the foundation has had a long time to settle, and probably won't go much farther if properly dealt with and the site drainage is improved. However, repairing the foundation may be futile without the drainage improvement. Both are required to reduce the potential for any further movement.
  5. Given the facts as you outlined them, I would not succumb to the pressure to repair the item. It is the responsibility of the client to read the report in its entirety, and it is not your responsibility to read it to them verbatim. While I often note that the attic scuttle is not what I would like to see, it is not an item that would make it onto a summary page, as it is a minor issue. When I first started in this business, I always wanted to please everyone. I have since learned that you can not please everyone. While Nolan suggests that we should go over the report with the client, it is still incumbent on the client to read the report.
  6. Jerry, I would be happy to lighten up your photo if you would like me to. E-mail me directly with the photo (higher resolution would be better) and I will take care of tweeking it. E-mail to brooten@zianet.com.
  7. I will tend to lump them under one piece if there are lots of issues. If there are only a couple of items to list in the category, I will be specific. I also mark affected items (outlets as per your example) that need attention. Sometimes the problems are so great you really have no choice but to recommend calling in the electrician (or other professional) to clean up the mess.
  8. I agree with Robert. These things are almost always junk. Like everything, there are exceptions, but most have never been maintained, with everything from kid's toys to earrings in the box. Vents are nearly always improper. Plus, like all space heaters, they simply don't do a good job of heating the home. Recommend upgrading to a central heating system.
  9. With radiant ceiling panels, not all of the ceiling will be heated. There should only be enough panels installed to heat the room properly. In my home (I have this type of heat) Much of the ceiling is not hot, as those portions of the ceiling are just normal sheetrock. If you inspect a home with this type of heat and you have attic access, you can find the heated panels quite easily by lifting the insulation. You will immediately see the difference in the backs of the panels. In this area (Southern NM), when I look at a 12x20 room, there may only be 2 or 3 heated panels, with the remainder being normal sheetrock. Oh, by the way, my heating bills are on a par with the dino fuel heated homes around.
  10. I'll be pulling in sometime Wed. afternoon. Looking forward to meeting some of you in person!
  11. This was my slowest December in 5 years, but it was still respectable enough to pay the bills. I count on taking vacation at Christmas/New Year weeks, and I think I always will. Now, I'm going to the ASHI convention, so would have to stall people off for another week anyway. Here's hoping that business takes off in later January as it has in the past!
  12. By the way, what is that a dryer vent in the lower right portion of the lower photo?
  13. I have never seen anyone attempt anything like this. IRC says that duct material has to meet specific performance requirements. Since this is IN the duct, I would suspect that a AHJ who was thinking at all would question this installation. Sec. M1601 of the IRC gives the flame spread requirements. Obviously wood would not meet those requirements. In addition to all that, common sense would dictate that the wood in the ducts would be subject to different heat and humidity conditions that just couldn't be a good thing. I guess I would call this out and recommend consulting a heating professional.
  14. Jesse, I've been doing this full time for 5 years, part time for 2 before that, and have been in housing related businesses for 20+ yrs, and still learn something new every day. Kind of goes with the territory. If you ever get to the point where you think you know it all and never have to look stuff up or ask questions, you are in trouble. Learning is a life-long process, especially in a business like this where the technology keeps changing.
  15. Where I came from in MN log homes were pretty common, so I got used to the idiosyncrasies that they have. The biggest single issue that was different was the shrinkage and how it could affect other items in the home. Randy is right. It doesn't take a rocket scientist to find the rot.
  16. I can't find any prohibition in either the electrical code or the IRC for this installation. Doesn't mean (to paraphrase an old song) that "I'm lookin' in all the right places."
  17. "The key is in the full-time inspectors. It is almost impossible to put a solid number on the part-time inspectors, they come and go like a stray cat." Ain't that the truth... One of my competitors installs satellite dishes full time and does a little inspecting on the side. Another one is the handyman for one of the local real estate companies. No conflict of interest there...
  18. Armstrong appears to be the builders' furnace of choice in this area and appears to have been the first choice for several years. I can't say I see a lot of problems with them, 'cause I don't. On the other hand, this isn't a climate where a furnace gets a good test. If I was back in MN I'm not sure I'd be saying the same thing. Trane and Carrier were far more common there.
  19. Another good book is "American Shelter" by Lester Walker. It is about 10 years old now, but I think it is still in print.
  20. I've said it before on another forum. We sometimes forget that the average reading level of Joe Suburban is 6th grade. So, to get verbose in a report will only make eyes glaze over and serve as a non-prescription sleep aid. The best way to communicate is by using straightforward, common verbiage. Even though I have a great deal of education, I don't feel it necessary or advantageous to cram it down a client's throat. Inspectorspeak is a lot like legalese in that it can tend to get pretty exclusive. KISS...
  21. Chris, Is it really thermal expansion or just the "normal" settling. I really haven't seen any joint failure that appeared to be from thermal espansion, and this stuff is pretty common around here. If it is functional, I would most likely see it as a cosmetic repair unless there are some other circumstances involved.
  22. Just a word of caution about handing out copies of this or any other article from any source. This stuff is copyrighted and can not be reprinted legally without permission.
  23. Chris, In my area the Chamber of Comerce has a very strong web site. It is visited by nearly everyone moving to the area. It has definately helped another business I have in town, and I am going to add the inspection business to their site. I always hated yellow pages ads, but this past year I got several inspections that can be directly attibuted to the yellow pages ad. I don't have any big splash, just a one liner in the one phone book and a small box in the other. The ads were more than paid for by the fees generated. Just a couple of thoughts to add to your pile of ideas...
