RichNSpect
Locked-
68 -
Everything posted by RichNSpect
You might want to get this book: http://www.amazon.com/Dampness-Building ... 370&sr=1-2
I frequently find "White" Teflon tape on gas pipe joints, particularly on Water Heater gas supply pipes. Until I'm told otherwise, I will continue to write up the use of White (single density) tape used on gas pipe joints. If I notice that the tape is yellow or a light pink, then I don't write it up. A while back I found this excerpt on one of the Plumbing Forums: When double density PTFE tape first came on the scene it was also white, packed on a white spool and primarily only marketed to professional tradesmen through the plumbing or HVAC supply houses. Most plumbers quickly adopted it because it was quicker and easier to apply and made a much more reliable joint. Shortly thereafter many gas codes were amended to require the use of double density tape on gas joints. Once the codes were changed they began making the double density tape yellow so that the inspectors would have a visual indicator that the correct tape had been used, thus to this day the yellow double density tape is often labeled as "Gas Tape". As the PTFE tape industry evolved into more products they adopted a standardized color code. WHITE- Single density tape to be used as a thread sealant on NPT (National Pipe Taper) threads which are equal to or less than 3/8". YELLOW-Double density "Gas tape" suitable for NPT threads equal to or greater than 1/2" but not more than 2" Red- Triple density tape suitable for NPT threads equal to or greater than 1/2" but not more than 2". (NOTE-The package is a red spool with a red cover ring and plainly labeled 'triple density", but the tape itself appears as a pale pink color). GREEN TAPE- Listed as "OXY/MED tape"-certified oil free to be used on lines conveying oxygen and some specified medical gasses. COPPER TAPE- Contains copper granules and is certified as a mechanical thread lubricant but is not certified as a thread sealant. Kevin
Know the Building Analyst 1 Standard and you will do fine. The field text is more challenging than the written exam. Also get a copy of Residential Energy: http://srmi.biz/Bookstore.Professionals ... m#BABHIHFC Good Luck Kevin
joined ASHI
RichNSpect replied to John Dirks Jr's topic in Professional Home Inspection Associations
I've never attended that chapter meeting. Both are ASHI chapters, but yes, they are separate. Kevin -
joined ASHI
John, You will enjoy your experience at MAC-ASHI. I know I have Let's catch up at the next meeting and talk shop. Kevin ps....are you going to Inspection World in Vegas? It's a great experience as well, and hopefully I will see you there. -
Distorted vinyl siding from window reflection
RichNSpect replied to Martin Holladay's topic in Exteriors Forum
Here is an example: Click to Enlarge 38.37 KB Homeowner even tried to put up a shied to prevent it from happening. Kevin -
Thermal Imaging and Cost Effectiveness
RichNSpect replied to Jeff Remas's topic in InfraredThermography
I always say get the "most" camera you can afford. My first camera was a BCAM SD, and I wanted to sell the thing a week after I got it. I ended up using it for over a year before upgrading. John Snell with Snell Infrared has written a great paper about Infrared Camera prices and performance. I would highly recommend requesting a copy and reading it before making a purchase. You can get it here: http://www.thesnellgroup.com/WhitePapers.aspx The paper is called "Breakthroughs in Infrared Camera Prices and Performance - Building Applications" Hope this helps Kevin -
I rely heavily on my websites and word of mouth for residential work. On the commercial side, it really take a lot of effort. Kevin -
I currently have a FLIR T400 and I am very pleased with it's performance. I purchased my imager before the big price drops, so I paid just over 20K for mine. That's including software, extra batteries, and a wide angle lens. I could get into specifics about spatial resolution or thermal sensitivity, but most of the new imagers out now have pretty good specs for building work. The minimum resolution I would purchase is 160x120. That should be good for most residential work. However, if you even think you might be interested in getting in Commercial Thermography, then you want to get 320x240 imager. I would also suggest investing in a wide angle lens, it will help tremendously while conducting interior scans. I think one of the best cameras on the market today is the new Fluke TiR32 320x240. http://us.fluke.com/usen/Products/Fluke+TiR32.htm You can get this camera with the additional lenses for around 10K. Simply amazing!! I will be my next camera unless FLIR comes out with something better. Kevin -
I have not personally had an issue that I misdiagnosed and took heat for it. However, you bring up a good point. Infrared Thermography is not a "Point-N-Shoot" technology, especially in building applications. Ask any Level III Termographer and they would tend to agree that Building Termography is one of the hardest applications. There are so many variable to take into consideration. For peoples expectations, I try and manage as best I can. I give a short demo at the beginning of the inspection and explain in detail the limitations of the technology. One of the first things I tell my clients is that the camera cannot see through walls! For the most part, my clients that get the additional IR scan have been very impressed and satisfied with the level of service. I don't find thermal anomalies on every inspection, but I do most of the time. I would suggest to anyone who is interested in getting into IR, that they first take a Level I training class or the FLIR Building Thermographer class. Kevin -
John, There are many different opinions on how an inspector should use or incorporate Thermography into their business. I have always been under the opinion that the use of the technology goes beyond the standard visual inspection. Therefore, I do not include it in my inspections. I charge an additional fee and have the client sign an addendum to my Pre-Inspection Agreement. All of my IR services are extra and under a separate agreement. Kevin -
Couple of points: 1. I had my first IR Camera paid for within the first six months of offering IR services. 2. I have always offered IR as an additional service for residential inspections and have averaged about 10-15 clients a month who get the additional service. 3. I've been able to earn 18-20K p/year in additional revenue just for the additional IR scan with a standard home inspection. 4. I've been able to earn 60-80K p/year in additional revenue from offering IR services in Residential and Commercial Applications. There is nothing wrong with just wanting to use Thermography in residential inspections, but the real money is in commercial applications. However, it has been my experience that once word got out that I was using the technology, a lot of doors started to open up. I did a home inspection for one the owners of a local HVAC company in my area. He was so impressed with the technology, I now have an exclusive agreement with him to work with his techs in installing and troubleshooting radiant floor systems throughout my area. People find you because you have an "expertise" and they need someone to help them find whatever problem they are encountering. I mean, I have been called out on plumbing leak issues, moisture intrusion issues, roof leak issues, etc. In the beginning, it was just offering my clients an additional service to include during the home inspection. It evolved into a lot of additional residential work and eventually I started a new commercial infrared business. However, I cannot express enough the importance of getting the proper training. Kevin Kevin -
1) YES! 2) NO! Kevin -
B.C. Inspector On the Hook For $192,000
RichNSpect replied to hausdok's topic in News Around The Net
I don't know all the details, but the Judge makes a good point. Inspectors should be careful with requiring the client to sign a Pre-Inspection Agreement on-site right before the inspection begins. I've seen a lot of Agreements and some of them are three pages long. Our Pre-Inspection Agreements are legal binding documents and the client should be afforded enough time to review and read the document thoroughly. When Inspectors present the Agreement to the client on-site and require immediate signature, a crafty Attorney could argue that the document was signed under duress because the Inspector would not begin the Inspection until it's signed. I think that's a valid argument. Most Real Estate Contracts have 3 to 10 day Home Inspection Contingencies. So, if the inspection is scheduled on the last or second to last day of the contingency, then the client does not really have a choice in signing the document. They feel pressured to do so out of fear that they will not be able to find another Inspector in time. This of course is just one scenario only to make a point. I always send the Pre-Inspection Agreement in advance. Actually, when a Home Inspection Appointment is scheduled, the Agreement automatically goes out 15 minutes after the order is taken. It's all automated through the ISN http://inspectionsupport.net/about/. The client has plenty of time to click-n-sign the agreement and all of the pertinent information is captured when they do (date, time, ip address, initials, signature, etc.). So, they can't say they did not have enough time to read the Agreement. Kevin -
gas fireplace batteries
RichNSpect replied to John Dirks Jr's topic in Fireplaces, Chimneys & Wood Burning Appliances
The better question would be "why is there rust and carbon deposits on the bottom of the fireplace?" Seems to be moisture vapor leaking down into the bottom of the enclosure. That's why the batteries are corroding. Kevin -
sorry, try this one.... http://www.bpi.org/documents/BPIs_home_ ... andard.htm Kevin
BPI just released its new Home Energy Audit Standard for public review and comments. http://www.bpi.org/documents/BPIs_ho...g_standard.htm Kevin
Efflorescence and brown granules
RichNSpect replied to mridgeelk's topic in Foundation Systems Forum
The brown "saw dust" like substance could be Frass, which is made up of wood shavings, bits of soil, dead ants and parts of insects. Hard to tell from pics. Did you notice any ants? Not sure about the white stuff. Kevin -
Jim, This is an odd one. What you described is what usually happens when the fan motor turns on. The motor has "inrush current" when it's first turned on, which causes a voltage drop. The voltage change could be causing the lights to flicker. I think the NEC allows up to a 5% voltage drop. If you have a Ideal Suretest, you can measure the voltage drop. http://www.valuetesters.com/Ideal-Indus ... alyzer.php It could also be a loose or poor connection somewhere on the circuit path (neutral). Kevin
Good Information in this thread!! I just use the Preston Guide http://www.prestonguide.com/ I need the extra data that the book provides for Home Energy Performance Surveys. Kevin
Looks like a Clearstory, but could be a very old Flat-plate Collector. Although, it's very large to be a collector. Was it built into the roof? Can't see the back of it. Kevin
That looks like a 150amp split-bus panel, not a 100amp panel. Just because it has two 50 amp main breakers does not make it a 100amp panel. The top six breakers comprise of the service disconnect. Actually, the lower left "main" breaker has been split off into two breakers. Therefore, you now have more than six hand movements in order to shut off the power to the home. I would have written this up as a defect and encouraged the client to upgrade the panel, since there is no more room and there are double-taps. Kevin
The question is not how, but why Homeowners do strange things sometimes - see example below. Thanks for the info..... Kevin Click to Enlarge 50.88 KB
Are Studor Vents (AAV's) allowed on a sealed crock for a sewage ejector? More importantly, are they allowed to be in unconditioned spaces, like a crawlspace? I've been getting some conflicting opinions and want to get the straight scoop. I was under the impression that you can't use Studor vents when venting a sealed sewage ejector, because air must flow both ways in the vent as the pit fills and pumps out. Is that correct? Also, wouldn't the Studor vent be susceptible to freezing? Any help appreciated Kevin
