Terence McCann Posted April 27, 2005 Report Share Posted April 27, 2005 Howdy all: More that once I've seen a tar like material applied to cast waste lines. It sometimes has a blue outer covering and it looks cracked in places, this is where you can see what appears to be a tar base substance. Is this a leak repair method? TIA Link to comment Share on other sites More sharing options...
Chad Fabry Posted April 27, 2005 Report Share Posted April 27, 2005 Iron lines can be ordered coated with an asphalt emulsion to slow corrosion from agressive soils...is that what you're talking about? Link to comment Share on other sites More sharing options...
Terence McCann Posted April 27, 2005 Author Report Share Posted April 27, 2005 This was on a waste line in the basement however, it was up towards the floor joists of the first floor and was a wye fitting. The cast that connected to it and ran into the floor did not have this material on it. Perhaps the plumber, at the time, only had this fitting with this material on it when he was working on the home. BTW, the home dates to 1919. Note to self: Take better pictures. Link to comment Share on other sites More sharing options...
kurt Posted April 27, 2005 Report Share Posted April 27, 2005 It sounds like the wye had the emulsion on it; the plumber probably didn't have anything else in the truck. Link to comment Share on other sites More sharing options...
Brian G Posted April 28, 2005 Report Share Posted April 28, 2005 I don't know if they ever made a similar plumbing product, but I can't help thinking of plaster-bond when I read the part about the blue coating. Electrical is usually gray, used for harsh enviroments. You don't suppose someone used that instead...? Brian G. Link to comment Share on other sites More sharing options...
