Robert Jones
    1,568
Everything posted by Robert Jones
  1. Let me know when you get to the serious referrence stuff Michael[]
  2. Whoa! My hand grew before my eye's.[:-boggled
  3. Just ridiculous weather down there. I hope he and others are OK.
  4. I have yet to see a Sanyo and Preston's isn't helping.
  5. This is the middle/edge of the garage roof. Had to be squirrels, same damage at the eaves of both corners as well. Click to Enlarge 81.94 KB Click to Enlarge 50.96 KB
  6. Probably the one pissing on the seat[:-blindfo
  7. Two white feeds and I have no idea what the "u" shaped black wire is doing? This was feeding a jetted tub. 100 amp system. Click to Enlarge 74.77 KB Click to Enlarge 33.5 KB
  8. Was that one of those when you stuck your head through the scuttle and first saw it, you kinda of said wtf is that? Or where you pre-prepped by the view from the top? That is one of the better one's I've seen posted on here. Would that be technically consider lined?[:-paperba
  9. I am being told that there is a sump pump installed in this drain area. There are two cables feeding the area, so I am guessing they are correct. The only thing I see running to it, is the back left corner downspout! WTF! Click to Enlarge 65.42 KB Click to Enlarge 74.06 KB Click to Enlarge 79.68 KB
  10. Trouble maker. Shouldn't you be in Iraq or somethin'. . . Robert - why do Wisconsin couples do it doggie-style? So they can both watch the Packer game. Thanks for the laugh Jerry! I am a short timer. Leaving for my unit May 1st and due in Afghan first week of July. I am hoping the NFL lockout takes the entire season this year[]
  11. Yesterday's inspection. Service lateral was approx a foot from the window opening with the mast head enclosed in metal/vinyl wrapped eaves. Click to Enlarge 71.79 KB Click to Enlarge 32.87 KB
  12. Thanks guys.
  13. Can't say that I have ever seen this setup before. 90+ year old home, washer and dryer "relocated" to the utility basement. What is visible in this pic is the hose connected to the home's drain line. In the second pic it shows the white drain line which is also part of the washing machine drain line. I don't think I have ever seen a "t" like that. Click to Enlarge 63.12 KB Click to Enlarge 59.06 KB
  14. Frickin hilarious!
  15. Jim, Do a search for this topic and you will find it has been covered a lot. Opinions on software are as varied as the personalities that frequent this forum. Do you have any building/construction experience?
  16. Red, I would take your advertising dollars and spend anywhere else but there. The realtors are still going to refer who they refer no matter what name is on the folder. Typically, by the time the folder is in the clients hands, that decision has been made. Concentrate on your website, do a door hanger for homes that may need an annual type inspection(home owners). You'd be shocked at how many people don't keep up on the maintenance of their home, or go in their crawl space/attic areas. A home inspection for home owners. Just my humble opinion.
  17. I am game Marc, or I guess anyone else that might be interested. I am not going to sanitize it unless your in my area. To much damn work!
  18. Do you have another pic of the setup? Was there a thermostat in the basement that might have turned on in floor radiant heat?
  19. Does the home have radiant floor heat?
  20. Sorry for the delay in response. Mike your explanation of the restricted vents due to flat work is pretty much on the money. This is a custom home with an in ground salt water pool in the back yard and nothing but flat work along the sides and back of the home. The crawl space cavity was dry and fungus free. It looks as though the vent was in the process of being installed and then stopped. Would you call for the fan installation to be completed? Or since there is no negative effects of not having one, just let the client know what it is and the theory behind it.
  21. Marc, I am not sure if it was for the dryer. It was only partially installed. So the reason for it would be to help get the lint to the exit on a long dryer vent run?
  22. 4 year old home and this in-line fan was partially installed in the crawl space. Possible attempt at conditioning the crawl? The flex duct is not connected but ran to the other side of the crawl cavity. Click to Enlarge 67.76 KB Click to Enlarge 45.8 KB
